RDU Rebuild
rlc3854
Rob
Amite LA
2022 Maverick, 2020 Edge
Looking to see if anyone has had their RDU rebuilt under warranty. What led to the rebuild, time frame for parts and completion?
Chops
Lobo
Maybe you’ll be the first? What model/year & mileage are you at? Why do you think you may need a rebuild? Am I being too nosy?
rlc3854
Rob
Amite LA
I have a 2022 Lariat AWD with 4K towing package with 33K miles. The vehicle started to have a growling noise at slow speeds turning. After inspection by the selling dealership they stated the RDU needs to be rebuilt. There are a few TSB's out on the issue.
I've never heard of a dealership doing that in-house, generally they will just get a replacement assembly.
But at the same time, I bet some dealerships do rebuild transmissions and differentials.
mavhopefull
Sam
Earth - Northern Hemisphere
1984 Mercedes Benz 300D Turbo
Very interesting. I was hearing the same thing on my 2022 Maverick and the noise went away after draining and refilling the RDU. I'm at 61k right now so I think I no longer have coverage. That stinks!
Bulletin NumberApplies toDescriptionRemedy
TSB 25-23512022–2024 Maverick AWD (plus others)Chatter/Shudder at low-speed turnsDrain & refill RDU fluid; use ESST if needed
rlc3854
Rob
Amite LA
I'm thinking that draining and refilling the RDU would work, not sure why they went straight to the rebuild option.
Branson C.
Branson
Oklahoma
2005 Yukon XL
I had my RDU drained and refilled at 78k miles. I am now at 106k and it has happened again. I have an appointment with the dealership this month.
Cancunbadlands
Cancun
Cancun
Dealer will just get a replacement assembly, it's been reported before at the Bronco Sport forum (Badlands, First Edition, Heritage Limited)
rlc3854
Rob
Amite LA
what are the symptoms that you experience?
rlc3854
Rob
Amite LA
DO you know what the wait times are for a replacement unti?
Snox801
Levi
Spring Lake Michigan
My 24 I swapped for redline rdu fluid. Seemed to work much better for traction. About 2 mo th ago I had the same weird sound after turning. Random awd disabled signals. Then nothing. Towed a lot of trailers in ff road adventures and about 20k miles. No such sounds again and everything seems fine.
Cancunbadlands
Cancun
Cancun
dpequip
SC
2023 Lariat Maverick 2023 OBX Bronco 2016 F350 4X4
My RDU failed at 21K my understanding is there are no parts available to repair these and no repair is to be attemped on the unit. This is a Dana part and is replaced as a unit. Mine was replaced under warranty no issues. I looked up the part Ford list was around $900 so not real expensive for what it is. The labor to replace looks like a PIA.
rlc3854
Rob
Amite LA
So is your truck dead in the water?
Monkeybread72
Dereck
2024 maverick lariatt
Had my rdu and ptu replaced under warranty around 45 thousand miles for a similar issue binding on under turns. Under warranty was in an escape for a bit over a month.
