Putco tailgate light bar
dc73pdsgt
Tucson, AZ
2023 Ford Maverick Lariat Hybrid
Just received the Putco Freedom Blade tailgate light bar. Part of the wiring, besides the taillight harness is that the bar has to be wired to the fuse box (fuse that activates with ignition switch) and to the 12v battery. There is a 12v battery jump point inside the engine compartment by the fuse box. Does anyone know if this jump point is capable of being wired to Instead of having to run the lead to the battery positive terminal itself? It would save me A whole lot of time.
BlueSpec1
Gene
The jump point stud (Copper?) looks to be press fit into a bus link that bolts into the DC bus.
So probably can't put much torque on it.
I used 2 nuts and fit a ring terminal between them.
12 Volt Jump Point - Press Fit Stud Rear
Ford Maverick Putco tailgate light bar 12 Volt Jump Point - Press Fit Stud
dc73pdsgt
dc73pdsgt
Tucson, AZ
Did you wire something up to the jump point? Was it a light bar or the one I have? The post looks like I may be able to just thread the connector over it and tighten with a bolt.
dc73pdsgt
dc73pdsgt
Tucson, AZ
Also is it a hot point? I’m guessing Putco set it up like this to provide power to the relay in the harness which then controls power to the light bar by being connected to a switched fuse Such as the BLIS system fuse.
BlueSpec1
Gene
The jump post is hot all the time.
I wired to an anderson powerpole for connecting a battery monitor and charger.
dc73pdsgt
dc73pdsgt
Tucson, AZ
Kewl I’m gonna try using that then, saves me from having to extend the hot lead all the way to the battery. Thanks for the help!
dc73pdsgt
dc73pdsgt
Tucson, AZ
So I spoke with tech support at Putco today and they confirmed the jump point should be ok to connect the power harness to. Now to find a bolt the same size to use the threads to secure the power cable from the light bar.
dc73pdsgt
dc73pdsgt
Tucson, AZ
BlueSpec1
Gene
dc73pdsgt
dc73pdsgt
Tucson, AZ
Thanks
