Power reduction on extended high speed driving?
GPSMan
Many
You confirmed your truck is normal.
DreamWeaver21
Germany
F250
I just drove a 1000 miles mostly on the interstate at 70 plus in west Virginia on grades of 7 to 8% for continuous periods of up to 7hrs on our return with no issues on power and or temps. I noticed no power reductions at all
I haven't noticed issues at 70 or 75mph either. Really only seems to be an issue during periods of driving at 90 or 90+ mph which isn't common or legal in the states. I am sure someone has done it though. I never saw the temp gauge move when I had the issue. The truck just didn't want to give all it has anymore. :)
notfast
Los Angeles CA
'26 XL hybrid AWD 4K tow
I'm pretty sure you overheated the generator, which is not tied to the gauge on the dash, you need a scanner plugged into the data port to read generator temperature.
You CAN NOT sustain over 50% power output in a Maverick for more than 10-15 minutes. The generator heats up.
That's also why driving Priuses from Los Angeles to Las Vegas sucks. They make great city cars, but sustaining freeway speeds over mountain passes with the A/C on and carrying a bunch of people/stuff is a no-go.
GPSMan
Many
The temperature gauge stays "normal" from 180 to like 250 degrees. Then jumps to "hot" all at once when a trouble code comes up; just FYI.
Don't quote me on the 250 value but it's close.
AutobahnSHO
Will
S.Carolina
Maverick, Miata
It's really wild how the HP required to fight wind goes up exponentially. I got much much worse MPG at 90mph than 75mph in my SHO there.
And even the Civic I traded in for my Mav this year got ~42mpg at 65mph and only about 38mpg at 75mph....
