#fire
Installed a motor for the Manual Rear sliding window in my 2022 XLT. Wanted to use the OEM Switch as well. Was a fun project, quite the investigative project trying to find the right connectors for Everything.
-Purchased a Motor assembly with cables from a Lariat wreck for 150$
Mounted motor with Rivnut Inserts at existing location. Added 2 standalone 5 pin relays below the motor (also with Rivnuts) to stay with the schematic. I already have ran 0 gage wire for my Inverter behind the backseat so I stole power for the load side of the relays from there.
Purchased a switch bezel from a wrecked Lariat on ebay, found the correct 6 pin molex connector on mouser to interface with the rear sliding motor switch. Ran 2 twisted pair from the switch, Pin One power input (spliced into White/Blue wire out of Pin 2 on the C22BOF connector of the BCM) to stay with OEM schematic and wired a ground to pin 6 of the molex to provide ground for the backlit switch LED. Pins 2 and 3 was a twisted pair ran to the control side of the standalone relays in the back.
The Lariat Bezel had the push to start switch port, I used that space and added a 12 Volt Accesory plug.
