Power Inverter Question
Sage
Sagebrush
Rockies
2024 Maverick
After reading through many threads on this subject here I haven't found a clear answer for my question.
What I would like to know if I can use a 4000 Power Inverter that plugs into the round power source in the front center council of cab?
BlueSpec1
Gene
Sage
Sagebrush
Rockies
2024 Maverick
Yes a typo. Well, no use carrying one around anymore than. Thank you very much.
JLB
Ridgecrest, CA
Maverick XL 2.0L AWD
A 400W inverter will run from a 15A 12V socket. Just be careful to plug less than 150W appliances into it. Higher loads will inconvenience you with a blown 15A fuse.
Sage
Sagebrush
Rockies
2024 Maverick
You can use the 400 watt inverter if you connect directly to the battery.
Nice I will work on a way to get that accomplished so I can use a drill or small electrical tool when at the ranch.
Thank You!!!
DokDream
Jay
North Hills, CA
2023 Maverick
I really looked forward to adding a DC/AC inverter to my Maverick. Now, I think a bank of roof-mounted photoelectric cells and storage battery would be a more durable, more powerful solution.
