Owners manual
Carlitos_92
Thanks for regurgitating this completely liability-driven disclaimer language written by lawyers. :LOL:
CajunMick
Heman
Houston, Texas
2023 XLT Maverick
Just looking at my truck, can see no off roads. If going up a mountain with reasonable graded road, guess ok.
Blue_Max
Orlando, FL
But but it is virtually the same as 4x4 :LOL: . And even with the offroad packages it is still not the same as a Ranger 4x4 or any other 4x4.
Correct. It's a softroader even with offroad options.
Surly Old Bill
bill
Richmond, CA
2024 Maverick XL
keep in mind when most urbanites and suburbanites say "offroad" they actually mean "off pavement". Doubtful anyone is headed off through the woods forging their own path, like I did in high school in a Fiat 128 FWD 4dr. And it did it very well.
notfast
Los Angeles CA
'26 XL hybrid AWD 4K tow
Was about to say, it would depend on what "off roading" is defined as. I've been on double-track dirt trails that were smoother than paved roads, and I've been on dirt roads that would shake your fillings loose. The Maverick with regular AWD I think will be off-road enough for 95% of what I need to do "off road", which is basically driving green circle (easy) trails to get out in the back country a bit.
To me, having a more capable off-road vehicle shines in two aspects...when you want to tackle more challenging trails, or when off-roading isn't the primary goal; getting somewhere is. Like, if I need to go tow someone out on a moderate trail, I can just throw my Nissan Frontier into 4WD and get there quickly with minimal drama, whereas a Maverick AWD might be pushing the limits of its capability and have to be driven slower and more methodically.
Speaking of capability, to me, vehicles are really only fun at such limits. You'll hit those limits a lot sooner with a Maverick AWD, so you could have a blast carefully navigating your way through an obstacle that a 4x4 with low range and lockers would just walk right over.
Oscarcat
Eric
Encinitas California
I interpret AWD to mean added traction in wet and slushy conditions. I also take it to mean, just like FWD, an AWD is suitable for improved unpaved roads. I also interpet it to mean when I load the bed with bikes and gear and the front end is lite, AWD will give me the traction I need to get up a gravel road without spinning my front wheels as is the case in a FWD Mav loaded w/gear.
But NOT rock hooping [sp?] and forging streams with boulders deeply rutted dirt roads etc.
Haven't used it yet for this - but it better one-up taking the Mercury Sable station wagon on some winter backpacking Ozark back roads to trail heads that got sketchy many times.
Never had to dig our way out, or add rocks/bark/branches - but bounced around a bit with some scraping.
And I'm just talking FWD Maverick - AWD would be incredible for those areas.
Someone here is in AR (@Ozarkbeard) - the higher graveyard entrance to Richland Creek Wilderness Area, doubtful that's been improved in 15 yrs.
Cherokee
Marty
2026 Ford Maverick Tremor
Mine regularly see’s hard, steep grades up gravel roads. I’ve got two ways up to my house. One has a 14% grade. This climb cannot be done with a Newer Rav 4 Toyota or a Subaru when things are dry and loose.
My mini truck does just fine in low and slippery mode.
If I leave it alone in normal mode and also not in low it makes the climb but I can tell the engine and drive train is working unnecessarily harder.
The Subaru struggles bad going up. If one tire breaks loose it becomes a one wheel drive.
The Rav 4 is not much better.
I found out with my wheel power meter that slippery puts equal power to all four wheel on my climbs.
I am also the only AWD up here that can stop and restart on the steep parts.
Mines just a ECO Lariat AWD and cannot lock diffs, I’m good.
My second way up is longer but the grades are several shorter ones at no more than 10% grade.
