OEDRO Hard Tri-fold Tonneau Cover Installed
BennyMav
Ben
Orange, VA
2024 Ford Maverick
Installed a OEDRO Hard Tri-fold Tonneau Cover today and must say looks pretty good. I found Oedro on Amazon if anyone is looking for a hard cover.
Ford Maverick OEDRO Hard Tri-fold Tonneau Cover Installed 20240913_144219
Ford Maverick OEDRO Hard Tri-fold Tonneau Cover Installed 20240913_143114~2
Ford Maverick OEDRO Hard Tri-fold Tonneau Cover Installed 20240913_143053
Ford Maverick OEDRO Hard Tri-fold Tonneau Cover Installed 20240913_143124
Very nice. Great choice.
Best part. It is hard not soft. It can't be sliced open. By some low life or kids walking by for kicks.
Like this 👇👇
Ford Maverick OEDRO Hard Tri-fold Tonneau Cover Installed 20240913_201638
The only other choice I feel is better, would be the BakFlip mx4. It is more money $$$. When the BakFlip folded up and forward it offers protection to the rear window, while loading large items or something that may shift while braking.
Good luck
kkreit01
Korey
Olathe, KS
'22 Maverick, '17 Grand Cherokee Limited 4x4 V6
Looks good. Are the panels metal or some sort of poly/plastic?
Toddman45
St. Louis, MO
Looks like a nice trip fold cover.
Toddman45
St. Louis, MO
Most all the hard folding covers are a very thin aluminum.
kkreit01
Korey
Olathe, KS
Some (like the Extang Solid Fold) are Thermoplastic. The (very) thin aluminum ones do not stand up well to small hail. I always see tons of them on Marketplace -- with dents all over.
BennyMav
BennyMav
Ben
Orange, VA
2024 Ford Maverick
The listing does say fiberglass panels and the other materials I'm not sure. Going to wash the truck later today and we shall see how waterproof the cover will be.
The top is actually waterproof.
It is going to be the areas around where it attaches to the front, water will pool where there isn't any area for it to drain like a regular truck bed. The top rail that has areas for water to seep between.
Showing in my pictures.
Depending on how tight you have the back clamps. You may have some seepage at the tailgate. Seeing as how the tailgate has a small upward spoiler like lip. That prohibits water from draining off the back, but most of that should run down inside the back side of the tailgate and drain through the bottom gap.
That is where you are going to get water seepage.
Good luck
Ford Maverick OEDRO Hard Tri-fold Tonneau Cover Installed 20240817_090927
Ford Maverick OEDRO Hard Tri-fold Tonneau Cover Installed 20240818_080841
Ford Maverick OEDRO Hard Tri-fold Tonneau Cover Installed 20240914_095509
BennyMav
BennyMav
Ben
Orange, VA
2024 Ford Maverick
It is going to be the areas around where it attaches to the front, where there isn't any area for it to drain like a regular truck bed. The top rail that has areas for water to seep between.
Good luck
Yes. Just finish washing the truck and sure enough I have water coming through. The second picture. That's the location water is getting in but not a whole lot. I will head out tomorrow and see what I can find to seal that leak.
LSS
Scott
Fort Bragg CA
2024 Maverick XLT FX4 4K towing SIBL Iconic Silver Metallic
As an electrician we use duct seal in underground conduits to keep them dry. That is what I used. It fills in all voids. In the Coast Guard it was known as monkey sh*t.
Toddman45
St. Louis, MO
This is a leaking point, I put some thick foam weather stripping there to fill the gap on both sides where the bed rail pieces meet. I used 1/2" w x 1/2" l x 1/2" h piece of foam.
Ford Maverick OEDRO Hard Tri-fold Tonneau Cover Installed Screenshot_20240917_235549_Gallery
BennyMav
BennyMav
Ben
Orange, VA
2024 Ford Maverick
Good idea. I will give the monkey sh*t a try. Thank you good sir.
Don806
Don
SE Ohio
I have this cover and weatherstrip near the cab and I used plumbers putty on the side where Toddman45's pic shows a water leak point. have had no issues other than water getting in around the tailgate at times during hard rains
Toddman45
St. Louis, MO
Try some tailgate weatherstripping, I got a whole 10 ft roll for $30 on Amazon. Keeps the water out at the tailgate as well. After I installed the cover I hammered it when I washed it everywhere nook and cranny with the hose sprayer and I had only one small drop right at the top of the tailgate on the left side.
So the tailgate weatherstripping really helped keeping water out.
https://www.amazon.com/dp/B00IPQWXZQ?ref=ppx_yo2ov_dt_b_fed_asin_title
Ford Maverick OEDRO Hard Tri-fold Tonneau Cover Installed 1726696063757948104906453225335
Ford Maverick OEDRO Hard Tri-fold Tonneau Cover Installed 17266961001915596966961004053683
Timothyd
How much?
