Need help with winter wheels
chaseshawn
shawn
ontario canada
2025 maverick lobo
Does anyone know if 17” wheels clear the lobo front brakes ? I can’t find any info just that it comes with different front brakes
Carlitos_92
Check out your spare. Pretty sure the Lobo comes with a 17", so it's not the diameter that would necessarily be the problem.
Wheel offset is another story...
colinl
Colin
ICT
Maverick OEM 17 alloy rims will clear. anything else it's hard to be certain without test fit.
Escapologist
Niagara Region, ON
Test fit is best check. Had one back in the day, 14" temporary spare, 15" wheels on the car, temp spare fits of course, try 14" alloys, couldn't even reach bolt holes. bouncing off the caliper. Try a 14" steel I had hanging around, because alloys are somewhat chunky monkeys, and I could just about get it on, but it was scraping. Used to be common in the past though that you could get a size lower steelies on than alloys.
However, the restriction on fit has been known to be at the back caliper on mavs, where a 16" couldn't be squeezed on, but if you do find 17"s in a cheap alloy instead of steels, be sure to check rear clearance as well as front.
Sgt.Gator
Gator
Bend Oregon
2025 Maverick Lobo, 2020 Edge ST
Tire Rack now lists wheel/tire packages for the Lobo. That is very recent, before they always said they had nothing to fit the Lobo. They now offer 17", 18", 19" & 20" Winter packages for the Lobo. The good thing is they guarantee fitment.
colinl
Colin
ICT
I see they have a checkbox for standard or aggressive fitment.
With aggressive checked, I see it's suggesting a 245/45-20 which is not really that aggressive, but it's more useful than suggesting a 225.
Cancunbadlands
Cancun
Cancun
Look at your spare tire
Sgt.Gator
Gator
Bend Oregon
With snow tires narrower is better than wider.
colinl
Colin
ICT
yes, and definitely not 20s. sorry, my comment was kinda off topic, but it was what I was curious about when I started digging into their Lobo options.
Sgt.Gator
Gator
Bend Oregon
Well yeah if you're sure there's asphalt down there, within a foot or so, otherwise you wanna go full tundra buggy balloons.
Correct. I was assuming that since this is the Lobo forum we weren't talking about off road blasting thru 2 feet of snow in a national forest!
Cancunbadlands
Cancun
Cancun
