Maxzina-Roof Rack Cross Bar Available Now!
Cruzer
Adrian
Santa Cruz, CA
2024 Maverick Lariat Hybrid
The racks look nice, I would probably only put them on when I need them, are they designed to be simple and quick to take on and off the vehicle?
f1jim
Pacifica, CA
2025 Maverick Lariat
Got the rack installed this morning. It all installed fine . All bolts must be loose to get everything to fit well. Instructions could be better. The video in the link on the contents page would not open. Important thing is getting the measurements equal side to side and front to back. No measurements supplied. Looks just like the photo at the beginning of this thread. Feels secure and strong. A slight noise at 65mph with nothing attached to the bars. Not as bad as I thought it might be. I am pleased so far.
AMTRV
Norris
TX
24 6.7 Tremor, 22 Bronco Badlands, 25 EB AWD 4k
It would have been nice if the like to the installation video in the box worked!!!!!
f1jim
Worked fine for me this morning…….good rack for $139.
tlast
MD
2023 Maverick
I can't find these on Amazon anywhere. Did the listing get pulled?
OB1e
Massachusetts
CG LUX XLT
Any chaffing from the metal bracket on the roof paint right above the window?
Maxzina
Maxzina
Diamond Sponsor
New Jersey
Maxzina
Maxzina
Diamond Sponsor
New Jersey
f1jim
Is the installation video on our manual unable to open properly?
AMTRV
Norris
TX
No chaffing yet. I used a bit thicker rubber pad in place of the rather thin gaskets that they provided.
I’ve had mine off a couple of times as I was adjusting from side to side and there is no sign of chaffing problems.
I’m actually very pleased with the way the bars fit.
I did wrap my front bar with black paracord to check the wind noise and it worked very well.
Again, I am well pleased with the purchase.
f1jim
Pacifica, CA
All I received was a piece of paper that lists the parts included along with a link to a video that refused to open. The pieces were rather easy to put together with some common sense and a tape measure. I used the video in this thread to help. I am pleased and find the rack a great value.
f1jim
Gvmumbral
Gerardo
Pasadena, CA
Honda Element
What if 2 sets were installed in the roof? Would the weight capacity double? Could i then instal a RTT? The lightest tent from C6 is less than 80lbs. Plus 2 people of 180lbs, is perfect for the 440lvs if this is even a possibility. Maybe it depends on the actual weight the roof can handle???
MYMAVXL
Chuck
Connecticut
Would love to purchase these but Amazon shows them as “Out of Stock”. Any info on when they will be available?
Aguy
US
bicycle
The issue is the antenna may be in the way, unless you could lift the RTT. If someone could post a picture of a piece of plywood or a surfboard or snowboard on the rack and see if it clears the antenna, that would be helpful.
Maxzina
Maxzina
Diamond Sponsor
New Jersey
f1jim
Thanks for your feedback!We will check the video link on the instruction manual.
