Maverick windshield replacing..
CaliMav68
JL
Ohio
2022 Maverick Lariat AWD EB
Yep, that brings back memories. Many years ago I had a very similar experience. Out of curiosity i did a google search and was a little surprised on the result i got (cut/pasted below) 🤷‍♂️
AI Overview
Small objects, like rocks, crack windshields more easily than large, heavy objects because of pressure concentration (P=F/A). A tiny stone concentrates high-velocity force into a minute area, exceeding the glass's localized strength, whereas a large, blunt object spreads its force over a wider surface area.
  • Pressure over Force: The key factor is 20,000 to 24,000 psi of pressure, which is roughly 60 pounds of force, needed to crack a windshield. A small, fast-moving object concentrates this force to create a fracture, often causing a "bulls-eye" or "star break".
  • Mass vs. Velocity: Small pebbles, often from construction zones, have high velocity and small mass, concentrating energy at a sharp point. A large object might hit with higher overall force, but if the impact area is broad, the force is distributed, reducing the chance of breaking the laminated glass.
  • Weak Points: Tiny chips from small debris act as, which can grow into large cracks due to heat or vibration, according to this Reddit post.
  • Laminated Structure: Windshields are made of laminated safety glass, designed to dent or absorb impact from larger, blunt objects rather than shattering immediately, as described in this Anthony Volk Glass article
Don't post AI please
BLUEOVALRACER
Ravenna,Ohio
2025 Maverick XLT AWD
Maverick windshield replacing really appears to be a problem and a safety issue.... this should be reported to the national vehicle safety director and then be covered by our Ford motor company as a recall issue..
A guy in another Thread about windshields said He knew a Family in the windshield replacement business. And they told Him they don't see any more Mavericks needing windshields replaced than other vehicles so You're SOL IMO. The other Thread is "Is Windshield susceptible to breakage" Post 6!!
