marker light blowing out
Two r’s
Ron
Washington
96 Geo Tracker; 2022 GMC Canyon AT4, 2024 Mav XLT
Hi, I have a 2024 Mav hybrid. Does anyone know if basic filliment marker lights will blow out if the rest of the vehicle is now equipped with LED conversion bulbs/FORM Lighting clusters??
I have replaced the standard marker bulbs 1 time now since converting all the other lights, dont want to spend the cash again if I must use LED in those also.
Tbone289
No, there is no negative impact to incandescent bulbs resulting from converting other bulbs to LED. The voltage on the circuit will be the same, and the incandescent bulb will pull the same current as always.
rick52
Rick
2026 Maverick / 1967 Mustang Restomod
I have the same problem with the front marker plate light.
Two r’s
Ron
Washington
Thank you Tbone289. That helps me isolate and reason the problem out.
