Anyone ever try one of these on a Maverick?
https://www.lundtruck.com/hard-fold-bed-cover/2022/ford/maverick
only $575
only $575
You're right and I believe the only thing hard about it is the frame itself. Seems expensive compared to the Gator Tri fold setup which I believe is almost a few hundred bucks cheaper. I think Hard Cover is pretty misleading, says right in the description that it uses a soft vinyl top.How exactly is that called a hard folding cover? Sure looks like a soft material stretched over a folding frame. Hard pass....
It says it has aluminum sub panels. If you look at the pictures, and not the video, you can see the aluminum panels sandwiched between the vinyl and frame. This has a place, but it’s not on my truck. For someone who needs cheap security it seems to be an option.You're right and I believe the only thing hard about it is the frame itself. Seems expensive compared to the Gator Tri fold setup which I believe is almost a few hundred bucks cheaper. I think Hard Cover is pretty misleading, says right in the description that it uses a soft vinyl top.
It does look like AL sub-panels on the main folding parts but there are also sections in between that have no aluminum panels and are just the vinyl. To me it seems like those sections where it folds and has no aluminum, just the vinyl negate the security of the aluminum panels?It says it has aluminum sub panels. If you look at the pictures, and not the video, you can see the aluminum panels sandwiched between the vinyl and frame. This has a place, but it’s not on my truck. For someone who needs cheap security it seems to be an option.
Cut the vinyl and you still have an aluminum frame and panels attached to the truck from underneath. Cut a hard roll-up along the splines and you have pretty much the same scenario as cutting the vinyl on this. It might be easier to get into than some other designs, but it’s certainly more secure than any soft tonneau.It does look like AL sub-panels on the main folding parts but there are also sections in between that have no aluminum panels and are just the vinyl. To me it seems like those sections where it folds and has no aluminum, just the vinyl negate the security of the aluminum panels?
