Low budget rack system installed.
Bilbo_B
Youngstown, Ohio
Ford Maverick XLT 2022 2.0 L Ford Escape 2017
I found a thread on this forum by Bry
https://www.mavericktruckclub.com/f...t-bed-rack-installed-on-side-bed-rails.28561/
about a low budget rack system that uses the Ford 'cargo management system C channel tracks for a ladder rack.
If you have this:
SKU: NZ6Z9955200A
Maverick 2022-2024 Cargo Management System Kit - Includes Cleat Tie Down Kit.
Then, with a bit of modification of this:
https://www.amazon.com/dp/B0B7WJV9G3?psc=1&ref=ppx_yo2ov_dt_b_product_details
(HECASA 4.9' to 7.8' Adjustable Aluminum Roof Ladder Rack Capacity 400 LBS Compatible with Open and Enclosed Trailers Cargo Vans Trucks Pickups Universal )
you can have this:
This rack system has an "Adjustable Design: Extendable Length: 59" to 94-1/8". Adjustable Height: 22" to 26". Designed to meet a variety of truck bed sizes "
The catches are that we all have different set-ups and spacing/spacers may be different. I have the Truxedo soft Tonneau roll-up and the side rails for the velcro attachments extend into the bed area a bit. As a result the spacing has to be fit so that the upright posts can fit between those side rails for the Tonneau.
Ford Maverick Low budget rack system installed. 100_0996_S
From this above pic, you can see that the upright rack post just fits inside with about a 1/4" to spare.
To do this, I needed about 2" of space. I used an "L" square to measure the spacing. Between the C channels (On my truck) is about 54 1/2" of space and the Tonneau beam sits about 2" inside of the C channel. I figured that the extra inside and outside box channels that has to be cut from the ladder beams, I could build up to about 2" and With the 1/4" thick brace that is welded to the upright, that gave me the spacing. My bolts are 2 1/2" long 1/4-20 stainless attached to
"Strut Channel Nuts, 1/4-20 Spring Channel Nuts with Zinc Electroplate Finish, Long Spring Nuts Great for Use with Strut Channel (10 Pack)" that can be bought on Amazon.
Ford Maverick Low budget rack system installed. 100_0997_S
The spacing pieces are about 8" long and I could actually cut 6 of the inside box channels from the two cross bars.
I could also cut two outside box channels from the outside with some left over for the approx 50" of width needed to clear the bed sides.
This can be done with a few power tools.
A simple hand jig saw with a metal blade, a drill, and some way to grind the pieces smooth and straight. Of course a belt saw and a stationary drill would be more accurate :)
One issue is that I tried to make the rack as tall as possible and in the center, it isn't quite above to cab roof line but I can always add some padding over the rails.
Anyway, I figure that this is about as sturdy as the Ford Cargo Management system can hold. I find that the rack feels solid. When fastened to the truck, there is about no wobble from side to side and fore-aft and if I try to find movement, the truck starts rocking on it's suspension springs. I figure that each rail can hold at least 200 lbs of dead weight and if properly tied down can carry my canoe or something like an extension ladder quite easily.
Bilbo_B
Bilbo_B
Youngstown, Ohio
I've been thinking about the uprights and I'm probably going to replace the self-tapping screws with regular stainless bolts. The instructions are very limited but suggest that the self tapping screws are for tapping into steel box trailers and may not be proper for aluminum. So, I need about 8 more 1/4-20 by 1- 1/2" bolts for a good fastener.
Bilbo_B
Bilbo_B
Youngstown, Ohio
Ford Maverick Low budget rack system installed. Screenshot 2023-03-06 082421
So, my rack height is actually 27" as measured in this pic. because I maxed out what is available BUT the cross bar is only 22-1/4".
Bilbo_B
Bilbo_B
Youngstown, Ohio
Next up: I want to find an appropriate material to make a bed divider to install on the side rail system.
Bilbo_B
Bilbo_B
Youngstown, Ohio
Ford Maverick Low budget rack system installed. 448308468_10221548464415765_9204769751796469029_n
Ford Maverick Low budget rack system installed. 448307129_10221548465295787_8650785099385383827_n
Ford Maverick Low budget rack system installed. 448312612_10221548465855801_8991435796305559775_n
jeff_J
Minnesota
His and Her XL mavericks, Gray and Blue
Ok after seeing this posting I bought the cheap ladder rack described from Amazon for $128. It took 6 hours of fabricating but it is now on my Maverick. The unit is build well and attached only to the bed tie downs so I can quickly remove it. Happy with the purchased and the utility it adds to the Maverick.
Bilbo_B
Bilbo_B
Youngstown, Ohio
Ford Maverick Low budget rack system installed. 099673899_n
Ford Maverick Low budget rack system installed. 483752197_n
