Long drive towing at maximum weight
rogerl1016
Roger
Iowa
2024 Maverick
i have a 2024 hybrid with a tow rating of 2000 pounds. I can rent a small camper that has a dry weight of 1667 pounds. I will be traveling by myself and light. I would like opinions as to whether traveling 3200 miles (some mountain) at maximum towing capacity would be pushing it too much.
The Real Maverick
Jack
It will be fine.
Rule of thumb:
Don't keep the power meter above 50% for longer than 3 minutes without a 2 minute rest in between and this truck will pull anything you put behind it.
Just slow down a couple or 5 mph if you see the needle constantly above 50%.
Above 50% is fine for accelerating, passing, etc. Just don't keep it higher than 50% for long periods.
IT IS AMAZING what 40% power will do so don't worry.
I tow 3200 lbs all the time.
I keep it 65 MPH and under.
(50 MPH on hills)
Never came close to overheating.
Escapologist
Niagara Region, ON
We're a dozen years out from the "Liar's Poker" era of truck tow ratings, so you can reasonably expect it to do what it says on the tin.
  • Haha
Reactions: AVC
