Location of tail light Fuse
swtiming8
Wayne
Mishawaka, Indiana
Focus
I have no tail lights. Where is the fuse controlling tail lights
RoyalTeaDee
North Carolina, USA
Dodge Caliber R/T
I don’t see anything that calls out tail lights. Do you have to dismantle the fuse box?
My guess is it would be the left and/or right hand side enhanced exterior lightning module. Should just have to remove the cover to the fuse box to access the fuses. I don't think you're dismantling it.
swtiming8
swtiming8
Wayne
Mishawaka, Indiana
Focus
Maybe dismantle is to strong but manual talks about removing the connector to me that’s dismantle.
Old Man
Nebraska
2023 Lariat
Or the module could be bad.
There is no discrete fuse for the rear taillamps and much of the lighting for that matter. The BCM monitors the current draw of the circuit and disables it via transistor switch if it determines there's an overdraw.
Edit: I see you've been flat towing. I'd guess it may be something with the wiring/equipment if you added any to operate the lights.
'Right/Left Enhanced Exterior Lighting' is just the high beams which are one of the few lights with their own fuses.
