Lobo Turbofan Wheel Weight?
Chops
Chops
Lobo
Another way to get the weight of the wheel is subtract the weight of the tire from the total weight of the wheel/tire combo.. I think you can get the weight of the tire from the tire manufacturers specs. IDK, just a thought. Sorry, but your 30.5 lbs is just for the wheel or is that the weight of the wheel&tire?
Weight for the wheel only.
I subtracted 26 lbs for the listed weight of the Wrangler HT. I also subtracted off the weight of me because both my scales require feet on the scale to to register:)
Chops
Chops
Lobo
Cool to see what the back of the wheel looks like!
I was a bit surprised to see the “fan fins” back there. I was expecting a flat dull surface. Saw a lot writing/markings in my picture that is too blurry to read. Going to check it out when I rotate down the road:)
Buggy Man
Summerfield Fl
2025 Maverick Lobo, Meyers Manx clone dune buggy
There is a “fan” on the inside, cool. Can’t remember where I heard/read “Moonstone”, but I’ll refer to them as their rightful name - Turbofan!
Time to weigh these big boys…
THAT is pretty cool. I did not expect the fan blades on the backside of the wheel. Like my, I think most people thought it was just the "look" of the wheel. Turns out there is a real reason for it.
Thank you for your effort and posting.
Also thanks to the person that posted the links of the history of the TURBOFAN wheel.
r0tax
CO
2025 Lobo 402A VB
They’re lighter than I thought!
So I’m thinking 30.5 lbs per wheel. That is not too shabby.
OZ Racing makes a high end & strong “turbofan” rally wheel - and it weighs 26.7 lbs.
Thanks for doing this, and the pics.
~30.5 isn't terrible for an OEM, 19" wheel.
r0tax
CO
2025 Lobo 402A VB
I wonder if those fins help with brake cooling, since the face of the rim is otherwise quite blocked off from fresh intake from the front side?
NIKwithoutaC
Nik
Indiana
1986 Mustang, 2026 Maverick Lobo Sport
30lbs is definitely on the heavier side when you consider how narrow the rim is, although truck wheels tend to be heavier in general. I'm curious how much the optional spoked wheel weighs.
Chops
Chops
Lobo
The original purpose of the turbofan wheel was for brake cooling. Catlitos_92 in post #12 shares a great link to the history of the turbofan. Invented for brake cooling - banned for pro use because too aero:)
Chops
Chops
Lobo
Info on internet points towards a weight of 37lbs for the optional spoked wheel. I was expecting the Turbofan to be a 40lb boat anchor and was pleasantly surprised.
r0tax
CO
2025 Lobo 402A VB
30# isn't terrible for OEM on a 'pickup'.
FocuST OEM snowflakes were 25#: (stock wheels = 18x8.5, 55mm offset, 25#)
You can get aftermarkets in the upper teens - low twenty pounds, depending on size ofc.
Taking 8# off at every corner likely would make a difference in handling/efficiency/torque application, but i still like the Ford Turbofans..
sva50233
Henry
'23 XLT
These wheels are reminiscent of Ronal Turbo wheels that Mercedes 190e, BMW e30 and VW GTI guys used to sport in the late 80's early 90s.
r0tax
CO
2025 Lobo 402A VB
Thanks for bringin this back to the top, I was looking for stock Lobo wheel weight again. :p
Looking at wheels once more..
56.5 lbs for stock Wheels and Tires+TPMS/valves.
30.5 - 18.6 = 11.9 lbs less per Wheel
11.9 * 4 = 47.6 lbs less Total of wheel wt
18.6 + 29 = 47.6 lbs per Konig wheel + 245/55R18 tire
56.5 - 47.6 = 8.9 lbs Saved per wheel and tire
8.9 * 4 = 35.6 lbs Saved Total of wheel+tire wt
That is a lot of weight savings for unsprung, driven weight. While still upgrading to a much better tire/compound
This gunna be goooood. ;)
Ford Maverick Lobo Turbofan Wheel Weight? 1760584159916-fx
Ryom
PA
2025 Maverick Lariat 4K BAP Eruption Green
r0tax
CO
2025 Lobo 402A VB
single digit % change in performance, objectively.
but subjective 'gains' in 'driver experience', which is likely the more important aspect of this decision, for me.
Allen King Jr
Allen
Springfield Missouri
2019 Grand Caravan GT, 2006 Mercury Mariner
Official weight of the wheel only is 37lbs according to my parts screen.
