LOBO logo installed
Buggy Man
Summerfield Fl
2025 Maverick Lobo, Meyers Manx clone dune buggy
We had a short rain storm come through today and it brought the temperatures down below 90 so I decided to install the LOBO logo.
First step was to clean the area with grease and wax remover. Next clean the area with alcohol.
I used a trimmed 2x4 and some shims to make sure the letters would be level with the truck.
With the template taped to the tail gate the backing was removed from the letters and they were installed. The template was carefully removed and the letters checked to make sure they were firmly attached.
All in all it came out pretty good but I probably should have mounted the logo a little bit higher.
Total time was about 15 minutes.
Ford Maverick LOBO logo installed DSC04792
Ford Maverick LOBO logo installed DSC04793
Ford Maverick LOBO logo installed DSC04795
Ford Maverick LOBO logo installed DSC04794
Tbone289
I looks pretty good, but I agree it would look better up higher. I've noticed that, on the '22-'24, Ford applies the stock badges (Hybrid, AWD) even with the centerline of the sheet metal under the taillight.
Ford Maverick LOBO logo installed 1753992237437-g2
Cancunbadlands
Cancun
Cancun
Finally! Looks #sharp
Bradley
Bradley
Tennessee
2017 F150 King Ranch, Lincoln GT, 1969 Mercury Cougar, 2025 Maverick Lariat
Interesting. My 2025 Hybrid AWD did not come with any decals or emblems.
Tbone289
The 2025's don't. That's why I specified '22-'24. The 2024 FX4 also has no tailgate emblems.
Looks Great, I wouldn’t change a thing. Well Done
Bradley
Bradley
Tennessee
Buggy Man
Buggy Man
Summerfield Fl
Why did you use a bubble level instead of just measuring up from the bottom of the tailgate?
Frist I checked to see if the whole truck was level. Then I checked the bumper, it has a very slight curve so my parallel trimmed 2x4 needed a couple of shims to make it level with the truck. I also checked to see that the bottom of the tail gate was level - it was.
I found it difficult to measure and mark the location using the bottom of the tale gate. Much easier to use the trimmed (square) 2x4 and rest the 1/8" thick "template" on the flat surface and tape it to the tail gate. It was easier and less chance for error that way.
Ford Maverick LOBO logo installed DSC04762
Ford Maverick LOBO logo installed LOBOlogo_install
Buggy Man
Buggy Man
Summerfield Fl
