Sorry for taking so long giving details. Went and reinforced the stock license bracket with 6mm rivet nuts. Then using a euro style license bracket and aux light mount, I screwed it into the stock license bracket bolts holts. I got 6mm x 1.50 flathead Phillips bolts for the top bracket and 6mm x 1.00mm for the bottom. I had to drill into the aux light bracket in order to fit the actual license plate screw. Make sure you leave at least an inch and a half gap from the top of the bumper to the bracket. This way you can install the lights. I installed a quick disconnect from the light to the power line. This way you can remove the light easier or upgraded your lights anytime. I wanted to mount a light to see better in bad weather conditions. But want something that could be removed without permanently damaging the Maverick. I’ve seen where other have cut out the grill and other pieces. The light is an 20” light, that has white and amber light combined. So far have not had any issues. It been installed for 3 days now. No noise on the highway that I have noticed.
