License Plate Mount - FX4 Tow Hook Option
pxpaulx
pxpaulx
Minnesota
OK, if the rear is mounted on the right when I look at it shouldn't the front plate also be on the right when I look at it to match?
It... Doesn't matter? 😁 I like it lop sided myself, plates in the same side of the truck, ie passenger side for both. If you like then opposite corners more power to you. There's no harm in being wrong sometimes! 😋
I like off sided also, just trying to figure out what matched, got it because they are both on my right when I'm driving = Match!
pxpaulx
pxpaulx
Minnesota
Got my plates today and installed. Here is the final result!
Ford Maverick License Plate Mount - FX4 Tow Hook Option IMG_20211014_144552
Ford Maverick License Plate Mount - FX4 Tow Hook Option IMG_20211014_144601
Ford Maverick License Plate Mount - FX4 Tow Hook Option IMG_20211014_144608
H0pelessOpus
Colorado
2022 Maverick Lariat - 2022 Explorer Timberline
Ta-da!
Ok, so this does work technically. Well enough that I am going to stick with when I get my plates in a few weeks.
The Maverick hooks are different from the ranger, in that the hook is open ended. however, it curls in on the open side more than enough for me to be comfortable using the linked mount from my original post.
Also unlike on the ranger hooks, the hooks are too recessed for the plate to display square to the truck, however it is only at a slight angle. Not enough for me to think it will look odd one mounted.
Looks good! Thanks for following up with pictures
Huntski51
Hunter
2022 Fod Maverick
Just did that over the weekend thanks to this post. Love the look and love not having to drill into the bumper. I also bought a rubber license plate holder to protect my bumper from the license plates sharp edges. In order to get the bolts to fit through I shaved down the backing of the plate holder with a razorblade. (y)
Ford Maverick License Plate Mount - FX4 Tow Hook Option Maverick
Connor
2021 F150
For those of y’all using the tow hook bracket, could y’all share more pics of it? The back side? How is it holding up? Any vibration at speed? Thanks
