Leveling Kits for rear drop only?
FSU TONY
Tony
South Florida
2025 Maverick XL 2.0
Most Suspesion Kits you level by raising or lowering the overall truck. Ive seen a couple where you just only lift the front 1 inch. Has anybody seen or heard of a kit that only lowers the rear so it levels out?
Ford Maverick Leveling Kits for rear drop only? 20250703_200725
Ford Maverick Leveling Kits for rear drop only? 20250703_200701
Ford Maverick Leveling Kits for rear drop only? 20250703_200644
Master Blaster
Master
Toronto
23 Maverick Lariat Hybrid
Leveling is weird on a truck. The rear suspension is set up to take a load without squatting, while SUVs and cars do not.
Sticks
Shawn
St. Louis
Some people in Facebook groups said they used stock rear springs from an Escape. The Maverick is based on the Escape, and the Escape is level, but you may not be able to haul as much weight in the bed.
As far as aftermarket rear-leveling kits, none exist.
FSU TONY
FSU TONY
Tony
South Florida
Looks like im going with the 1 inch leveling kit up front. Im trying to fill the wheel well as much as posible so i also ordered 255-65-17s. Im going to cut it close!!! If it doesnt work i will have no choice than get the regular spring lift that I beleive is 2 inches
Master Blaster
Master
Toronto
You're going to eat the front CV joints, but hey, its your money.
Tbone289
You think more because of the 1 inch front lift or the 255s?
The lift will put the CVs at a steeper angle from the transmission to the knuckles. Larger tires won't affect CV longevity so much.
AWD owners can use the Lobo rear springs to level, but I don't have a solution for FWD.
Master Blaster
Master
Toronto
The lift increses the CV joint angles, when they are already marginal. You're accelerating the damage, so they're going to fail even earlier.
BTW, I'm impressed that you got 255s to fit. Some people report that their 245s work, but only with SUV-style tires with rounded edges. Do they rub in a corner at full compression? Did you alter the wheel offsets from the stock 38mm?
FSU TONY
FSU TONY
Tony
South Florida
Great info. Would have thought the Lobo rear springs would lower it to much. I didnt pull the trigger last night on the 255 or 245. If what your saying works then for sure the 245s. Looking into it today!
FSU TONY
FSU TONY
Tony
South Florida
Havnt done it yet. Master Blaster just came up with what could be a great solution if it doesnt drop it to much
Master Blaster
Master
Toronto
I have not done it, but since the Escape is built on the same chassis design and sits level, I wonder if a set of junkyard Escape springs would do it.
Tbone289
chalupabatman
DFW
2025 XL
for the awd or fwd? I just purchased a 2025 and would love to drop the rear a bit.
