Is this normal a/c behavior?
Efab
Edwin
Nevada
Ford Maverick XLT FWD 2.0 EB LUX
So on my XLT i turn the recirculate button on but after a few minutes it turns off. Anyone else have this issue?
M.A.C.
Manny
South Florida
GMC Sierra 1500 Elevation
Make sure the fan light is on before you push the a/c button or the recycle button, turning off the A/C button should keep the fan on without cooling, even if you have the A/C off and you push the recycle button the fan will turn on (no a/c). The recycle button should stay on as long as you don’t press it again.
Sounds like you need to make a service appointment.
Aherpa
Iowa
Edge, Maverick Lariat Hybrid
Are you using the defroster at the same time? In certain modes, (defroster for example) the recirculate function 'times out', at least it does in my F150 Lariat.
Dturano547
Amityville, NY
78 Bronco Ranger XLT, 10 Ford Flex
I had a Ford focus a few years ago, company car, it had all kinds of issues from the ac related to recirculating or not recirculating... All kinds of moisture issues, horrible smell mainly, etc... because people would not switch between the two enough. Wonder if this is the solution to prevent it in the Maverick.
Ford Maverick Is this normal a/c behavior? RDT_20211210_2242525227823632650479078
Efab
Edwin
Nevada
made sure the defroster was off. But the answer is on the comment below yours. I guess ill have to use max ac in order to keep it on since its getting cold in vegas and the system appears to turn it off in order to avoid fogging
Efab
Edwin
Nevada
this is it! Thank you.
PapaDave
North Seattle
Maverick XLT FX4 VBlue & XLT hybrid A51
I wondered the same thing, turning off soon after i turned it on manually. Thanks for answering.
Decayed
yes
a car
These nanny features are annoying. If I want it set to recirc, it should stay set to recirc. If they include nanny features they should also include a way to turn them off.
ralatalo
Robert
NH
Toyota Yaris hatchback
So, you want the "I know better than you, do what I say and I agree not to complain about problems if this setting is enabled'
Seriously, one of the other members mentions all the issues that ford had to deal with, ie because users couldn't work them out themselves. So, while I agree with options to customize, I will tell you from a support perspective one of the first things we ask is if the problem still happens if they do back to the defaults. Doesn't mean we won't help them with the issue and their customization but does help narrow down the problem.
Decayed
yes
a car
Almost every vehicle I've owned has had a recir/fresh switch that stays where you put it. Never had a problem in decades of use. Why is it suddenly too complicated for us to comprehend? I can in fact work it out for myself and do not complain, so long as it does what I tell it to.
LadyMav
SJ
I’ve been wondering about the recirc as well…..not staying on, so I guess I have the answer now.
I typically leave it on at all times, mainly because I don’t like to smell the exhaust of the other vehicles near me. 🤔
LowLeadAV
Ryan
Lexington SC
Niro
My Kia Niro won’t leave the recirculation on unless the AC is set to the lowest temp. It will also change the location of where the air comes out from the face vents to the windshield vents for the same reason.
Rocko van isl bc
Rocko
BC Canada
1 22/23 maverick hybrid xlt
Did you end up finding a solution? Mines only staying on for 1-2 minutes then goes off also. Ugh. Mines the 2023 xlt model... I keep just putting it back on. It's like arguing with a 4 year old. Not getting anywhere.
Efab
Edwin
Nevada
just random behavior. Learned to live with it. Unless its on max ac or really hot inside cabin it will normally just turn off. I dont mind it now
Alter Ego
internet's darkest corner
Converse All-Stars size 14
In fact, they do. You have an ecoboost, which has the 12V battery. If you were to disconnect all wiring to the (-) and then (+) terminals, all nanny features will be disabled.
