Intelligent Adaptive Cruise Control Possible?
LilbluMav
Nick
Pacific Northwest
2022 Maverick Lariat
Has anyone done this? Ive got the option for intelligent cruise control but I get an error with it not being able to read traffic signs. I have TSR turned on but i just ran out of time today. I have a lariat lux with ACC
Im working on a list of forscan mods also for a video so far what ive done:
-added off road screen
-added mud/ruts and sand modrle
-Courtesy honk disabled when you take your key out when engine on
-global windows down
-(TSR) i got 2 bubbles testing to see if the 2nd one shows any signs of working....
-(personal) removed seat belt reminder for driver and passenger since my job sometimes has me driving around a lot.
- disabled honk on lock
I like to hear of there is anything on Intelligence cruise control if not let me know of some more forscan trick with the Mav! Thanks
Ford Maverick Intelligent Adaptive Cruise Control Possible? image000000(30)
Deleted member 15499
Guest
Yes, it's possible, I have it enabled and working, but outside of using it once, I run normal adaptive
LilbluMav
LilbluMav
Nick
Pacific Northwest
If you have any of the coding for forscan or where a forum page has some good information that would be great! Thanks
@nickn066 's posts suggest it needs to have an APIM with NAV so Sync 4 or maybe a 2023 Sync 3 unit and:
IPMA
706-01-01
xxxx-xxDB-xxxxx
I will try this code when i get home since im using xxxx-xxD2-xxxxx for the TSR
If you set it to D3 (or SLIF in easy mode) and in the IPC:
720-03-02 -- xx4x xxxx xx
720-09-01 -- xxxx xxxx 8x
That should give you the square traffic signs, FWIW.
Frankbread
Frank
Did anyone figure this out?
oneinch
Stanton
SE Pennsylvania
'22 Maverick Lariat
Ditto. If anyone has given their Maverick intelligent adaptive cruise control please share the details.
gkendric
Florence, Alabama
Mercedes Benz GLE350, E350 former 2010 F150 Lariat
I too would like to activate TSR (traffic sign recognition) but I'm also wondering if there is some modification to the time element that is implemented to require or signal you to place your hands back on the steering wheel. You get the gentle beep then increasing notice to return your hands to the wheel but I wonder if that time element is adjustable?
oneinch
Stanton
SE Pennsylvania
'22 Maverick Lariat
Put a weight on your steering wheel. This will fool the truck into believing your hand is on the wheel. So long as lane centering can see the road you can drive hand-free.
