- First Name
- Jim
- Mar 31, 2022
- Athens, AL
- Porsche 944NA, Mazda Miata, PT Cruiser Conv.
- Engine
- 2.5L Hybrid
I spent a good part of the last two days first installing Mabett’s side marker lights and then attempting to get the passenger side marker to work. Prior to beginning the install, I reviewed Fred’s Garage’s step-by-step YouTube installation video. (Fred thanks for producing the video.) I replaced the included wire taps with better pieces drawn from my bench stock. The light’s wires were passed through plastic wire wraps before routing to the headlight and turn indicator connectors to prevent the possibility of a short being caused by rubbing against sharp metal edges. The driver’s side marker worked fine as advertised. Not so with the marker on the passenger side.
The yellow wire went to the blue and green wire at the brown connector. As I look at the black connector looking forward. Left to right, the wires are blue, brown, black, and grey/blue. The marker’s red wire was initially tapped into the grey and blue stripped wire. The marker light came on and the turn blinker worked, but the steady light would not go off at any of the positions on the dashboard light switch. The brown wire resulted in the blinker working but nothing else. The blue wire gave the same result as the brown. I guess if I have a working turn indicator I’m half there. Has anyone else experienced a similar problem. If so, were you able to resolve the problem.
I really like what I see on the side that works. I appreciate the enhanced appearance and additional safety factor of greater visibility. I also need to call our Mabett’s representative to MTC. When I explained the situation with their product, there was no hesitation in offering a refund. I guess I’ll join the club of those waiting for Amazon to restock the markers.
