I need some help testing some codings on the 6.5inch Cluster or Hybrids!
EONR24
Swag
United States
2024 Ford Maverick XL
Hey everyone,
I want to make this thread to get some help in testing some codings that DO NOT work on my 4 inch cluster but MIGHT work on the 6.5inch Cluster or codings that are specifically for Hybrids.
CODINGS TO TRY
Ford Maverick I need some help testing some codings on the 6.5inch Cluster or Hybrids! Screenshot 2024-03-27 at 9.21.55 PM
EONR24
EONR24
Swag
United States
Can someone try this coding as well with the 6.5 inch screen and see if any of these show up when enabled? Change 3rd digit to "F" as shown xxFx-xxxx-xxxx to test in any displays or gauges show up.
Ford Maverick I need some help testing some codings on the 6.5inch Cluster or Hybrids! Screenshot 2024-03-26 at 1.34.30 PM
HEF51
Hef
Ohio
2017 Subaru WRX Base MT
Following. I'll let someone with a little more expertise than me try. But definitely interested anything related to the 6.5in display.
EONR24
EONR24
Swag
United States
There were several codings that I tested that did nothing on my 4 inch display. I suspect these codings to enable screens and menus on the 6.5inch display! I will be adding more to test!
HEF51
Hef
Ohio
Hey everyone,
I want to make this thread to get some help in testing some codings that DO NOT work on my 4 inch cluster but MIGHT work on the 6.5inch Cluster. The first coding I want to test should display Engine and Transmission Temperature!
NOT CONFIRMED TO WORK
Enable Temps on Gauges (6.5 inch screen only)
1. Go to IPC AS BUILT
2. Go to 720-07-01
3. Replace the two digits below with "A5"
xxxx-xA5x-xxxx
4. Write the changes!
Let me know if this works for the 6.5 inch screen! I have a couple more I will post on this thread that need tested too!
I dove in and tried this. I did not see anything pop up in my settings to allow me to view temp gauges nor did anything pop up by default.
EONR24
EONR24
Swag
United States
thanks for trying it!
EONR24
EONR24
Swag
United States
Adding another coding for 6.5 inch screen MAVERICKS to try. I would try enabling some of these below based on the codings in the picture.
michel
michel
brasil
ford maverick
Alguém pode tentar essa codificação também com a tela de 6,5 polegadas e ver se alguma delas aparece quando ativada? Altere o terceiro dígito para "F" conforme mostrado xxFx-xxxx-xxxx para testar em qualquer display ou medidor exibido.
Captura de tela 26/03/2024 às 13h34.30.png
[/CITAR]
Eu testei isso mas não funcionou
