I discovered a pull tab in fender well.
Status
Not open for further replies.
RadMan
Roseville, CA
While I was cleaning the truck yesterday, I noticed a small green plastic tab on the rear drivers side fender well near the shock. I pulled on it and the tab easily came forward and had extended to what appear to be a plastic string. I was afraid to pull more as I did not know what would get released. Anyone know what this is? THX
Ford Maverick I discovered a pull tab in fender well. IMG_0214
Ford Maverick I discovered a pull tab in fender well. IMG_0215
Tailender
Will
Poconos
Gas door opener.
I believe it is the manual pressure release for the pressurized gas tank which will also cause the gas door to open. Check manual
Clarkdonbran
Roseville! What’s your build? I’m the annoying guy in the white hybrid xlt. I’ve probably honked at you on PGB!
JimParker256
Cedar Park, TX
This "pull tab" is not referenced in the user manual that I downloaded. It may be a "service only" item, but it's definitely not shown in the owner's manual.
Dadmezz
Akron, Ohio
Subaru
Beware...might be Ford's self destruct option in case of lemon laws.šŸ˜…
rclee
Rob
Dayton Ohio
I could have sworn I read about that green tab somewhere in the manual. I just did a search on the online manual "fuel door" and all I saw was this.
Ford Maverick I discovered a pull tab in fender well. 1662909963680
mcc63303
St. Charles, MO.
sold 22 Hybrid XL now 24 Hybrid XL, 57 Chevy 454ci
I believe it's only on Hybrids, releases the fuel door if electric button doesn't work.
Aza
DFW
It’s in the html version of the owners manual
Ford Maverick I discovered a pull tab in fender well. 06AE974F-2922-4DD3-A1F7-00DE8F82B664
Maverickman74
Shane
Maui HI
Pull it to release the passenger side mirror.
Johnkn
MD
Careful, pulling it detonates a small thermonuclear device not unlike the one seen in the movie ā€˜Predator’ that Arnold S. Starred in. Poof...
Clarkdonbran
My build is XLT area 51. What is "PGB"?
Pleasant Grove Blvd. Within 5 minutes of living here I started abbreviating stuff like I’ve lived here forever! I’ll be on the lookout. I usually give a point and a thumbs up!
Status
