Hybrid engine performance question
Oggy
Michael
Finger Lakes NY
Forgive me if this has been asked, and for not knowing but...
If I order the hybrid, and I'm not happy with the acceleration, or overall power, are there mods that can be done to make this more powerful? I'm not looking to spend tens of thousands on modifications, or an engine swap, but I know you can tune the ecoboost...
Big_T
T
2022 Maverick XL Hybrid
I seriously suggest if you're not happy with 0 to 60 in the 8.5 second range you should get the ecoboost. Or a different vehicle.
FirstFord
Massachusetts
VW Jetta
You could search Prius forums to see what's been done as that's basically the same configuration.
But I expect that any changes to the ICE to boost output would require software mods so the modded engine would play well with the motor-generators.
I don't see any payback on your investment.
Jakb
Jak
Minneapolis, mn
23 XLT Hybrid
There is a good video of a 0-60 that should help. 13min 20 seconds about
Tuning a hybrid/Ice is gonna be tough
Oggy
Michael
Finger Lakes NY
You could search Prius forums to see what's been done as that's basically rhe same configuration.
But I expect that any changes to the ICE to boost output would require software mods so the molded engine would play well with the motor-generators.
Thank you for a helpful reply.
I'll look at those, not looking for anything crazy, but I haven't been happy with throttle response on the late-model vehicles I've driven lately. I'm not looking for high horsepower gains like are seen with turbo swaps, or boost increases....
Platinum2
MI
Ford
Neither am I. But I still like to be able to merge into traffic, or pass a semi-truck on the highway.
And I'm quite confident Ford engineers have provided this capability.
bgillen35
Brendan
St. Cloud, Fl.
'24 Maverick XLT, '22 Indian Chief
mav_can
BMW X3, 2018 Mustang EB Premium
Just the sticker alone is +5 hp.
Hm yes but you have to consider that the added weight is -1 hp. I opted out of the Lux package specifically for weight reduction.
mav_can
This isn’t a problem, except maybe if you’re towing and trying to pass on those two lane rural roads and you don’t have much space before the line goes from dotted to solidz
bombast
Pennsyltucky
2022 Ford Maverick XL, Hybrid
There seems to be two barriers to speeding up the Maverick, as I, a non-specialist, see it.
1. Hybrids are very much computer dependent . Futzing around with components, speeding them up, will play havok with the computer, and messing with the computer is probably a one way ticket to warranty voided town.
2. My understanding is that the Atkinson engine in the Maverick is kind of wonky from a mechanical perspective. It has variable pressure and is engineered to efficiently burn fuel, very much at the expense of power (Likely one of the reasons why its so low powered compared to other engines with its displacement). I suspect the very mechanisms that make the Atkinson ideal for a hybrid motor make it very unideal for performance modification.
Reviewers have done unofficial clocking of the Maverick's acceleration - high 6/low 7 for the Ecoboost, high 7/low 8 for the Hybrid as I recall. Both will merge just fine - I guarantee my Impala is doing worse than both but I'm not dying on the high way. I suggest you make your choice based on those numbers and not guess at future mods being made available.
EDIT: Also...
I did a quick google search for how to speed a Prius up and the internet said modify the suspension and fuck all else, so there's that.
STARCOMMTREY1
Trey
Boligee, AL
7.5 to 8.5 0 to 60 is fine. There always a time when Sub 7 0 to 60 was for performance cars
