thev8man
thev8man
Yep, I'm set at 32psi cold. However with the "warm" snap here in the 40s now I've had the pressure get upward to 37/38 running on the highway and could absolutely feel the difference. Promptly aired down to 32.
Booyah πŸ‘ŠπŸ½ 😁 πŸ‘πŸ½ πŸ‡ΊπŸ‡Έ
I love 40 psi
pa-outdoorsman
PA
2022 Maverick XLT, EB, LUX, FX4, 4K, Cactus Gray
Your truck looks great! Congratulations. The only thing I'd change would be running some bigger tires. I'm running the 2-inch Eibach lift springs on my FX4 and I have 11 inches of ground clearance at the LOWEST POINT, which is center of front bumper. Clearance is greater on sides and in rear.
I'm running 245/70s which helps with ride height as well. They do eat mileage. I'm getting 22-23 mpg in mostly rural, hilly terrain. But the truck is very functional for hunting and I have clearance for the front bumper even on those annoyingly tall curbs!
Ford Maverick HRG 1.5" lift kit for Maverick Tremor installed IMG_1870
Deleted member 30736
Guest
The HRG kits are well thought of in the Bronco Sport community and I bought one for my 2022 BS. However, I moved to the Maverick before I installed it. I contacted HRG to ask if there were any extra parts I needed to install the kit on the Mav. They quickly identified the ABS wiring relocation bracket that I needed. Their service is excellent. I'm looking forward to installing the kit and then putting some larger tires on the truck.
thev8man
thev8man
Tires are in the mix, I think if you had the Tremor bumper on your fx4 you'd be straight. I m looking to put the jjc-llc.com Tremor foglights on my truck next. I need more light of road
thev8man
thev8man
That's what I'm talking about
Bwicka
Lakeside,ca.
Looking good , great seeing in some dirt.
Tremor1942
Phil
Pennsylvania
2023 Maverick Tremor
Awesome keep it coming. Went off roading in the Pine Barrons in N.J was wishing I had more clearance. 90% of the time! Love the way the tremor handles on the open road and hwy so I'm very hesitant to lift it.
thev8man
thev8man
I loved the way it handled before as well. So far I'm enjoying the lift. I have plans to get bigger tires which will give me more height. But for now it's perfect. Im working on a road and off road comparison, I did some trips with my last Tremor Maverick. Once I complete the same tasks I'll know the pros and cons .
thev8man
thev8man
I installed my HRG 1.5in all the way around. I like it and in comes with alot of necessary geometry equipment such as rear sub frame spacers and traveling arm spacers.
https://www.hrgoffroad.com/1-5-inch-38mm-lift-kit-for-2022-2024-ford-maverick/
More pictures and ride review to follow.
UPDATE
LAST Tuesday I finally got to put on some bigger tires. I had a lot going on last year. Our house burn down and we lost everything give or take including our Pets.
I went with Pinza All Terrains sized at 245 70 R17.
I'll do a new Post.
Ford Maverick HRG 1.5" lift kit for Maverick Tremor installed 20250702_105914
Ford Maverick HRG 1.5" lift kit for Maverick Tremor installed 20250702_105941
Ford Maverick HRG 1.5" lift kit for Maverick Tremor installed 20250704_190848
Ford Maverick HRG 1.5" lift kit for Maverick Tremor installed 20250702_110026
Ford Maverick HRG 1.5" lift kit for Maverick Tremor installed 20250702_100700
Cancunbadlands
Cancun
Cancun
Booyah πŸ‘ŠπŸ½ 😁 πŸ‘πŸ½ πŸ‡²πŸ‡½
Any CV's problems reported?
JasonDroninAround
Jason
Hanford, CA, USA
www.youtube.com
2025 Ford Maverick Tremor
I may put a lift on mine someday, I'll probably wait until at least the the warrantee is over. I really think I want to go with sliders and maybe also skid plates first though.
JasonDroninAround
Jason
Hanford, CA, USA
www.youtube.com
UPDATE
I do a new Post.
Did you move your rear exhaust pipe? My thinking was that it would be good to keep it where it runs under the rear diff so rocks would smack the exhaust pipe instead of the rear diff :)
Ford Maverick HRG 1.5" lift kit for Maverick Tremor installed 20250413_070727
