How to remove hood lever so you can remove the trim panel behind it?
Zumakalis
Rob
Maverick XLT
How do you take off the hood lever so you can remove the trim panel behind it? I haven't been able to figure it out and it is quite irritating. I'm just trying to run some wire from the back to the engine bay and while we're on the topic does anyone know the best way to remove the black part in the second pic with the charging ports? I want to add a couple button switches there and run some wire so I only have to do it once.
Ford Maverick How to remove hood lever so you can remove the trim panel behind it? 20220828_135824
Ford Maverick How to remove hood lever so you can remove the trim panel behind it? 20220825_224416
Gullzway
OK
1968 Ford Mustang Fastback
I ran my rear dash cam wire down that side. I did not remove that trim piece, I think I just tucked it up underneath with plenty of room.
Ecl
Eli Lewis
Nv
09 hhr ss, 93 f250, 17 explorer platinum
There is a grommet through the firewall that is perfect to run stuff to the engine bay. That's what I did for my boost gauge. I can get you some pictures in a few.
Zumakalis
Zumakalis
Rob
Maverick XLT
I ended up fishing it through behind the panel like you said. Got a bit too focused on trying to take that panel off but I'm glad I read your post so I didn't waste so much time.
