Head Ache Rack on the Cheep
DavidLs
Texas `
Ranger/23 and 24 Mave hybrids
Ok Im insane I bought the cheep Headache of Amazon and Tried to install it. Universal Right?? Nope Not even. but for 129 Bucks and I had let it set in my garage until My Mav got here. I had to go for it. Universal was a big Stretch. Needed A grinder a Stove and a Nearby TSC.
Mounting it out of the box was a no go. Brackets will not work with a 2023 Mav. Cant send it back way over the Amazon 30 day return limit. I did not want the Bed caps to warp as I had seen posted. When I drilled the mounting holes and installed the rack the Black plastic end caps do not sit on the metal they stand off of it bt about 3/4 inch and they begin to warp upon tightening bolts down. ( Not Good) A trip to TSC. I Bought 4 way over sized nuts So the Mounting Bolts would slide right through them, Then I heated the Nuts up Super hot on the Shove. ( Glowing Red Hot ) Ran the bolts though them and Placed them over the Plastic end caps though drilled bolt holes through the holes in the metal. They Plastic Melted and Locked the Nuts in Place Flush & Level nicely with the plastic. They appeared to have sealed it all together, Awesome Now I had support. Then came the Washers. The Washers had to be ground to a very narrow profile I bought the thickest ones TSC had. Then a bit of heavy Rubber .The Ordeal was a Pain in the fanny. I will post Pics Later. But its solid and doesn't look Bad.
Oscarcat
Eric
Encinitas California
Mounting it out of the box was a no go. Brackets will not work with a 2023 Mav. Cant send it back way over the Amazon 30 return. But I did not want the Bed caps to warp. I drilled the mounting hole installed the rack the Black plastic end caps do not sit on the metal they stand off of it bt about 3/4 inch and they warp upon tightening bolts down. ( Not Good) A trip to TSC. I Bought 4 way over sized nuts So the Mounting Bolts would slide right through them, Then I heated the Nuts up Super hot on the Shove. ( Glowing Red Hot ) Ran the bolts though them and Placed them over the Plastic end caps though drilled bolt holt through the holes in the metal. They Plastic Melted and Locked the Nuts in Place Flush & Level nicely with the plastic. They appeared to have sealed it all together, Awesome Now I had support. The came the Washers. The Washers had to be ground to a very narrow profile I bought the thickest ones TSC had. The a bit of heavy Rubber .The Ordeal was a Pain in the fanny. I will post Pics Later. But its solid and doesn't look Bad.
You certainly put a lot of thought and effort into the project. Would love to see the photo of the finished job. If I had one thing to tell Ford it would be to make it easier and provide a more robust rail surface on which to install a rack on the Mav. People need them for paddle boards, canoes, and work, to haul long items that extend over the cab - a third cross bar so cargo doesn't bang against the roof, 8' and 10' ladders, etc.
Maverickman74
Shane
Maui HI
Kinda the same deal with the Ridglines. The first ones were impossible but the newer ones got a little better. Hopefully next gen Maverick has a squared off drainable front bed rail and robust side rails.
Ohh yeah let get some pics of this headache!
DavidLs
DavidLs
Texas `
Well Here are the Pics. Just a Note the area that is the closest to the Cab I Ground that down with a angle grinder for a better fit. If I had not it would have pressed to hard on the ABS. With A HF Angle grinder it took less than 10 min.
Ford Maverick Head Ache Rack on the Cheep DSC00591
Ford Maverick Head Ache Rack on the Cheep DSC00592
Ford Maverick Head Ache Rack on the Cheep DSC00593
Ford Maverick Head Ache Rack on the Cheep DSC00594
Ford Maverick Head Ache Rack on the Cheep DSC00595
DavidLs
DavidLs
Texas `
Hope It Helps
Maverickman74
Shane
Maui HI
Hey thats alright! Good job.
Oscarcat
Eric
Hello and thanks for the multiple pics - that helps me visualize your project. [I too have an Oxford white Mav with the raised black tailgate letters.]
Johnkn
MD
And I came here thinking I would see a headache rack on a baby chicken........
Mervin the Maverick
Ken
Sierra Vista, AZ
2019 Kia Niro, 2019 Hyunda1 Kona, 2002 Chevy S10
I’m not a fan, but I don’t know what your needs are. I would like to see the rack at the same height as the cab, but again, I don’t know what you need.
GREAT WORK on the install though, and especially figuring out what needed to be done.
GPSMan
Many
I just use Tylenol.
