Going to get the rail system. Do hooks need to me removed?
fuego
FL
All Honda one Ford
I’m about to get the rail system in bed. Do I need to remove this here? Ideally no. Anyone else self install a diy or oem part?
Ford Maverick Going to get the rail system. Do hooks need to me removed? 1755432010335-cy
Waterick
Laurens county SC
No, the OEM rail system sits in that indented area between those two hooks.
cyberdog
Ray
2023 Maverick Lariat Hybrid
You need to remove it, and the installation instructions for the rail system even state to remove them. - I attempted to keep them, however the track does sit correctly, nor are the bolts long enough.
Waterick
Laurens county SC
I stand corrected, @MavStangVa is right. Upon investigation I see that Ford uses that whole indented area for the rails and does not install the forward cargo hooks. Now, some after market or DIY solutions may shorten the rail to retain that hook YMMV. Mine has obviously not been used, being tucked up under my tonneau cover. The rear hook I've used many times to keep things from sliding around is not affected by the cargo rails. I have yet to really use my cargo rails using mostly the rear most part of the bed unless more is needed.
Cancunbadlands
Cancun
Cancun
The answer is yes
