Wheel and tire specsLooks great did, what size tires you put and did you use original rims?
Fifteen 52 Metrix 17x8 +38
Fallen Wildpeak 245/70
Where did you get the wheel spacers from?Never been a fan of Bushwacker flares but I’m diggin them on the Maverick
Yours is the first that I've liked the look of the fender flares on. They work REALLY well with those tires and rims. Do you have a lift on your truck? What kind of tires are those? Are they offset?Never been a fan of Bushwacker flares but I’m diggin them on the Maverick
its lowered now (not a fan of a lifted Maverick)Yours is the first today I've liked the look of the fender flares on. They work REALLY well with those tires and rims. Do you have a lift on your truck? What kind of tires are those? Are they offset?
It must be the spacers. How much are spacers? Do spacers affect anything other than looks?its lowered now (not a fan of a lifted Maverick)
here's my setup
Spacers 1.5” front / 2” rear
Steeda lowering spring (for Escape)
spacers were around $200It must be the spacers. How much are spacers? Do spacers affect anything other than looks?
[/QUOTE]Where is the tire rub happening and is it during regular driving or just lock to lock turning
only negative affect is the tire rub with them, but with the lower and wider stance the truck handles amazing.
running 245/70 tires (larger then stock) i think it rubs less after lowered.I wouldn't want that if the tires rub. Do you think they would run if it weren't lowered? Are you running larger than stock tires?
Supreme Suspensions - 2pc Set of... https://www.amazon.com/dp/B09YYB9576?ref=ppx_pop_mob_ap_sharecan you provide a link to the spacers you purchased?
Thanks
