Fuses
Frenchy
Bert
Taylorsville Utah
I am trying to find a 2025 hybrid specific fuse kit.
So far I have no luck.
Do you know if such a thing exist?
thank you.
Look in manual for the amps used. Has it's own section for Fuses.
Buy a kit that has the best mix - throw in glove box or under seat.
Never heard of a vehicle specific kit, but I'm sure it would be well overpriced for what you get.
Don't cheap out on brand though.
After this post - several threads with similar should show up at bottom now - and you can view pics of the fuse types incase you don't want to look.
But suggest looking so you'll know where to use these new fuses, and how to access since the underhood has manual instructions to get to it - not normal.
Ray-n-AVL
Ray
Asheville, NC
2024 XL Hybrid (Black), 2009 Yamaha V-Star Tourer
As far as I can tell there is no kit for the Maverick. There will be no best kit to buy since there are 6 different types of fuses and 22 fuses based on amps. One is marked as a circuit breaker so I don't think you will need a spare for that. As far as I can tell all the 'M Case' fuses are the slotted type but the higher amp ones are marked HT and I can't find what that means. There are 2 'J Case' fuses but I don't know if they are the normal or short variety. When you're counting fuses the Micro3 fuses take up 2 slots but it's one fuse. You don't say what model of truck you have but if you have an XL there will be a number installed fuses that you can consider spares for things that are not installed such as a moonroof, heated mirrors, heated seats, heated wipers, power rear window, etc. Hope this helps and good luck.
Ray
Frenchy
Bert
Taylorsville Utah
Thank you
Ray
Thank you Ray
BlueSpec1
Gene
2025 probably has some fuses that are the same, probably some difference too.
My 2023 Maverick has: Micro2, Micro3, Low Profile JCASE, MCASE+ Slotted fuses, and a 30 MAXI CB.
Low Profile JCASE
Littelfuse 0895040.Z 895 Square Car Fuse 40A Low Profile JCASE Cartridge Fuses Rated 58V
Littelfuse 0895060.Z 895 Square Car Fuse 60A Low Profile JCASE Cartridge Fuses Rated 58V
MCASE+ Slotted
Ford Maverick Fuses Maverick BJB - Littelfuse MCASE+ Fuses
Frenchy
Bert
Taylorsville Utah
Low Profile JCASE
MCASE+ Slotted
Excellent work. Thank you so much for your help and Happy New Year.
