Fuel fill error code, then trouble filling
Brent Karrett
Burnt
CBUS
Coyote, Lanche, Nauti,
Neck fills causes pump to shut off. Repeat about 20 times in order to fill up. Ugh !
help
Striped_Mav
2027 Maverick Lariat
We are going to need more information if anyone is going to have any chance of helping you.
What was the error you saw? Where was it displayed?
Did you have any trouble filling up before this?
Have you tried another pump since the problematic fill up? If so, did it work OK?
No codes or warning on dash, after you pressed the button for fuel door open?
You state error code - but failed to provide it - mighty useful for future reference.
It should have released the valve so air could exit the tank to allow fuel in.
While not under pressure, it doesn't sound like that happened also.
And that would result in a warning/code being set.
PCMP04B4:00Refueling Vapor Control Valve Stuck Closed: No Sub Type Information
Joe Strummer
Squamish, BC
2024 Ford Maverick XLT Tremor
I read somewhere on this Forum (so it must be true) that forcing more fuel into the tank after the automatic shut-off can damage the EVAP system. Highly not recommended.
Cancunbadlands
Cancun
Cancun
Forcing more fuel into the tank after the automatic shut-off can damage the EVAP system, is it a common practice?
If all you got was a filler neck's worth of fuel - would you really stop on the auto-cut off when you knew you needed WAY more?
Old Young Man
Patrick
Ormond Beach
2024 Maverick Lariat Tremor
I can’t use the high pump setting but I am never in a hurry I set the pump on its lowest setting and when it clicks off I stop. 24 eco boost. No problems yet
umpkey
Bunnell, FL
I had this same issue this morning. After hitting the fuel release door it took a longer amount of time then said something like fuel door not able to open consult owners manual. I hit ok and hit the fuel door button again and then it opened. I then had the worst time filling. After about a half gallon the pump clicked off, then would do this after about every half gallon filled like it was full. It appears that for someone reason the fuel was going into the tank very slow and causing a backup. The stopping of fuel was not from topping off cause I had about 50 miles to empty. I think a big contributing factor was it was 59 degrees out and was the coolest morning we have had here in Florida in a long time so maybe that is the case. Hope this helps or maybe someone else has some insight as well.
Post 4 is why.
Likely.
Did you have an error message on dash?
Striped_Mav
Well that is a lot more info than OP provided. I wonder if we're ever going to get more of the story.
Did you ever figure out what was wrong? Did it happen again?
Which valve are you referring to here?
Detailed in the rest of my post...
In like the 2nd section, but at least not the 2nd paragraph!
Striped_Mav
Sorry, the formatting lead my eyes to believing that was part of the footer, so I skimmed over it. Now that if for what it is, your post makes more sense. Thank you.
I'm curious how common this condition is.
Mavnificient
Sean
2024 Maverick Hybrid Lariat, 2006 Dodge Ram 1500 4x4 Laramie
It has happened to me once in the 3 months or so I've owned mine.
