frozen fuel door ecoboost
Brian_J
Akron, Ohio
'22 HPR Maverick AWD 4K LUX
every winter, my fueldoor freezes shut several times. not the door itself, but the push to latch mechanism. it seems to fill with water somehow, even though there's a gasket around the pin itself. i've tried spraying the pin with wd-40, and recently coating the pin with silicone grease, but it still freezes. anyone else having this problem? anyone at a dealer available to check the p/n and see if they have redesigned this part#? i have a oct '22 build EB.
thanks
fossil
ernie
ohio
try a dry silicone or graphite powder
WD and S grease will likely gum up in the cold
Brian_J
Brian_J
Akron, Ohio
I have a silicone spray I’ll try… once I get it open lol.
OleFordGuy
icegradner
British Columbia, Canada
2022 XLT Maverick Hybrid
If you do use isopropyl alcohol don't get it on the gasket, or other rubber seals.
