Forscan Changes Not Saving
SFBay
San Francisco, CA
2025 Ford Maverick
2025 Ford Maverick Hybrid XL
OBDLink MX+ OBD2
Forscan 2.3.65
Hoping someone can help me with Forscan. Currently I am trying to disable all of the seatbelt minders from the IPC (as built) module. I found the appropriate settings to switch to all zeroes, and tried to use the "Write" buttom in-line and "Write All" button at the bottom of the app to apply the changes, but it keeps reverting back to the defaults.
Does anyone know what I might be doing wrong and how to overcome this problem?
Silly Willy
Lawrence
West Virginia
23 Mav.
OBDLink MX+ OBD2
Forscan 2.3.65
Hoping someone can help me wi Forscan. Currently I am trying to disable all of the seatbelt minders from the IPC (as built) module. I found the appropriate settings to switch to all zeroes, and tried to use the "Write" buttom in-line and "Write All" button at the bottom of the app to apply the changes, but it keeps reverting back to the defaults.
I got 5 male inserts from TEMU 5 bucks stuck them, no more warning on dash.
Sig-vicious
US
2024 Maverick XLT Tremor
Have you tried any other combinations, to maybe just disable only a single indicator or two? Just wondering if it thinks the data you are writing is corrupt or disallowed. This will give you an idea of it's going to accept anything at all.
I had a time trying to disable mine with FORscan, had to try a lot of different settings. I was only trying to get rid of the pop up that shows them when "OK". I did that, but still have the popup until I latch my belt, but at least it goes away after I latch it.
uga
SE USA
2026 Ford Maverick XLT
You need the newest beta for a 2025
FORScanSetup2.3.66.test20250228.exe
scharris99
Daytona Beach
2025 Maverick XLT
Get a paid license, then load the latest beta version.
