Flat tow Base Plate
Aribba76
Kellie
GA
2024 Ford Maverick Hybrid Lariat
Hello fellow Maverick owners. I am the new owner of a 2024 Ford Maverick Hybrid Lariat FWD.
I bought it so I am tow it behind my Class C Motorhome.
I have searched and studied what I need to purchase and the general consensus is the Demco Base Plate
I would love to get everyones opinion on this as well.
I want a base plate that functions correctly and one that takes little or no trimming.
Thank you so much.
If Demco is the answer, could someone please give me the model number
Thanks so much
rk06382
Robert
Alaska
2025 Velocity Blue Maverick Lariat Hybrid, 1990 Ford Ranger XLT SuperCab
Welcome to the Maverick Truck Club forum from Alaska!
Please post pictures of your new Maverick. :camera:
Aribba76
Aribba76
Kellie
GA
Here ya go, my new ride. I still have so much to learn.
Ford Maverick Flat tow Base Plate IMG_5256
Ford Maverick Flat tow Base Plate IMG_5264
Dave O
New Smyrna Beach Florida
From my past experience flat towing for the Maverick IMO the RoadMaster Baseplate and TowBar is the best option, very clean installation, strong and well designed and least destructive - I have others brands installed on my other vehicles but definitely recommend you look at the RoadMaster set up for the Maverick
Ford Maverick Flat tow Base Plate IMG_5960
Ford Maverick Flat tow Base Plate IMG_5257
Ford Maverick Flat tow Base Plate IMG_5255
Bert Rooster
Albert
Rio Rancho, NM
97 Toyota T-100, 06 Jeep Liberty, 2018 Tiffin MH
Ford Maverick Flat tow Base Plate Maverick hooked up 01
I installed the Roadmaster base plate on my 2023 XLT Hybrid and am using a Roadmaster Falcon All Terrain tow bar.. That baseplate required some significant trimming and removal of the lower active air vanes. I believe the Demco base plate requires less trimming and leaves the active air system intact. Go take a look at etrailer.com, they have several base plate choices and have detailed installation instructions and videos for each one. I have heard the BlueOx base plate is least desirable due to the wider mounting points which effectively shortens the towbar which can cause binding or contact with the towing vehicle in sharp turns.
Dave O
Looks great however with the 2025 refresh and the relocation of the ACC Radar everything changed so they all started from square one and have similar but different approaches it was easy for me to immediately disqualify BlueOx for my 2025 with its wide stance so I focused on RoadMaster and Demco for me RoadMaster nailed this one
when I purchased my 2025 Lariat AWD Hybrid there were no options for any baseplates and I contacted both manufacturers and communicated with both through their engineering process after over 6,000 miles flat towing with this Maverick using the RoadMaster baseplate and RoadMaster NightHawk towbar Im happy with the installation and how it performs
Aribba76
Aribba76
Kellie
GA
Thank you so much. Did you have to do much trim work
Aribba76
Aribba76
Kellie
GA
Thank you for your valuable information. I will look into those options
bsenecal
vermont
, 2022 Ford Bronco, 1968 Ford Mustang, 2022 American Coach American Dream 39RK
What option did you go with for lights on the Maverick when towing?
I would rather not have to tie in to the factory wiring and am thinking about using magnetic lights that work on Bluetooth.
Dave O
I plug Into the RV and all the lights work perfectly everything syncs with the RV (running lights, brake lights, turn signals, etc) I purchased the kit when I purchased the RoadMaster baseplate and RoadMaster NightHawk TowBar no issues after flat towing this Maverick over 6,000 miles in 2025
Ford Maverick Flat tow Base Plate IMG_5044
bsenecal
vermont
Thanks so much for the info.
I will plan to purchase all the same parts for our 2025 hybrid so we can flat tow starting this spring.
Did you do the install yourself or have a shop do it?
Where do you purchase the equipment etrailer?
Dave O
I purchased directly from RoadMaster which I highly recommend they have amazing customer and product support something that third party retailers can‘t match IMO companies like e-trailer talk a good game but rarely can deliver.
i had a small local family owned business do the install and could not be happier with their work and attention to detail I’m very fortunate to have these guys near by. It took about four hours.
bsenecal
vermont
Thanks again for the advice.
Maybe we will meet out on the road.
I will be reaching out to Roadmaster directly.
Dave O
YW and it’s always nice to meet new friends when we are out in the RV - good luck and take care
ChuckT
Chuck
Palmetto Florida
2024 Maverick
Thank you so much.
Thanks so much
I installed a Roadmaster base plate on my 2024 Lariat and couldn't be happier. Have towed approximately 2000 miles behind me class C without any problems.
