Fitting Tremor Rims and Tires on XL?
drkeffer
Darryl
Washington St
Sorry if this has been asked. I recently purchased a 2025 XL Hybrid AWD. I have the opportunity to purchase Tremor Wheels and Tire take offs. Is there any issues I might need to be aware of?
Thanks
Hunters Edge
Sid
F150 crew
Thanks
I think they are both 17" wheels so they should be the same size wheel. The tire is AS to AT and from p225 to p235 which is .51 of an inch higher or adding about .255 of an inch clearance. It will change or askew your speedometer and odometer readings. This maybe corrected with forscan but not sure if that is available yet for the 25 or ever will be.
I would make sure the takeoffs are the standard or have been changed. They should be p235 -65r17
This may help
https://www.tacomaworld.com/tirecalc?tires=235-65r17-225-65r17
FischAutoTechGarten
Peter
Thanks
Yes, your truck will look instantly awesome! Are you prepared for that?
OleFordGuy
TheShark
You are correct!
Looks great, now get some Tremor stickers for the rear and you can have the only XL Tremor on the planet. 😁
