Factory spray-in bed liner opinions?
Charles Burke
Charles
Nissan Murano
Hello all,
Would like to hear comments regarding factory spray in bed liner. This vehicle will be garaged and receive very light use .
Thanks for your replies. Charles
Jared
Jared
Ford Maverick XLT
Hello all,
My factory spray in is high quality and was done perfectly. What would you like to know?
Charles Burke
Charles
Nissan Murano
Hello all,
Hi,
How is it set up for drainage ? I will be ordering a hard tonneau cover.
Thanks...........
The Weatherman
Dean
KY
Hi,
Thanks...........
The bed has several drainage holes front and back. The liner is well done and leaves those holes open so the bed will drain, should it get wet.
FOLIMON
Sean
Toronto Canada
Maverick XLT
Any chance you know the diameter of the SIBL drainage holes? I want to buy an inspection camera to inspect the gas tank.
Jared
Jared
Ford Maverick XLT
I don’t know your build number but, they are inspecting all trucks that are within a range that this happened in. The holes are very small and I can measure them but if you aren’t smelling gas, or seeing gas on the ground, chances are your fine. If you want to be sure, just tell the dealer you smell gas and they will check for you, on fords dime.
FakeCowboy
Mid Atlantic
2016 Subaru WRX
Personally I would opt for an aftermarket spray in bed liner. There is a video on Youtube where an F-150 owner with factory spray in bed liner wants it removed and a Line-x liner installed and when they remove the factory liner you can see there is zero prep work done and it almost peels right off. Line-x preps the surface by scuffing it for better adhesion which is probably why they offer a lifetime warranty whereas there are so many accounts of the Ford factory bedliner peeling within a few years.
JamesC
LI, NY
06 Mustang GT
I just emailed a request to drop the spray in bed liner from my XL hybrid order, maybe it will expedite my build some. I do like it with the Ford logo though.
FakeCowboy
Mid Atlantic
2016 Subaru WRX
I ordered two XL Mavericks, one with a spray in bedliner and one without and oddly the one with it was scheduled for production first.
