Factory Installed Drop In bed liner and bed power access
bbyBlue
Chicago
2022 Ford Maverick (VB), 1986 Lincoln Mark 7
Hey all do you know if you got the factory installed drop in bed liner if the accessory power will be able to be used or will it block it ?
Deleted member 12286
Guest
I had to take my side panels off and cut out the openings in the bed liner.
They don’t take the time to do it for you.
It’s marked on the backside of the panels to show you were to cut.
bbyBlue
bbyBlue
Chicago
Cool so then I assume I take out one bolt pull the liner back and take a dermal tool cut off disk and cut it off ?
Guest
Yes and the bolts holding the side tracks for tie downs also.
I used a body saw with a fine blade than hand filed the edges.
paneubert
Seattle
Can you confirm if the floor is pre-cut for the D-Rings, even if the truck doesn't come with rings? Not sure if the XLT came with rings or not, so you might not be the best person to ask if yours came with rings installed.
corbiem
corbie
texas
Do you know of the dealer will cut it out to reveal the panels?
paneubert
Seattle
I'm sure you could ask them to do it as part of the PDI process. They might charge you though.
