Ethanol free fuel
vezpa
EMG
IL/IN border
Too many to list.
I can get in up in WI and down in FL, but nowhere in the Chicago/NW Indiana because of our BS laws.
SLINGSHOT
Charles
NE Iowa
2017 RAV4
Actually it burns dirtier than Ethanol, but it causes less problems on rubber parts and o rings and is more stable over longer periods, that's why ethanol free is better for yard equipment and small engines and older cars that weren't designed for E gas. Normal ethanol added gas should be fine for your Mav as it was designed for it.
ACTUALLY ethanol polutes MORE than pure gas. PLUS, it takes gallons and gallons of water to produce 1 gallon of alcohol. Add in polution from the fertilizer and pesticides to grow the corn AND the fuel burned by the tractors AND the fact that you are using food for fuel. Gasahol is a loser. Why do we have it? Start by checking on how much Senator Grassley, from Iowa, and his son and his grandson have received from farm subsidies over the past years (hint: OVER A MILLION $$$) and yu will beging to see the waste and costs.
Eber1988
Scott
Wisconsin
2022 ford maverick
But it burns cleaner right? This may be true but not when you have to use more of it to get to the same place. I mean you are talking 4 miles a gallon roughly. So approximately 60 less miles and 2 gallons more used for the same distance.(just estimate with a 15 gallon tank. My f150 is 30 gallon) Plus like you said all the fuel and pollution that is produced or used to actually make the stuff. However it looks good if you spin the numbers and only show gallon for gallon pollution. The positive I guess is it gives a lot of money to the farmers who sell the corn and grow the corn for ethanol use.
