- Dec 15, 2021
- Oakland County, MI
- Ford Taurus & Maverick XLT Hybrid
- Engine
- 2.5L Hybrid
I found the hood mat on Amazon for 75 bucks and I watched the video. Does the front of the hood mat sag in the front? Also, you stuck on HDPE foam on the hood and then installed the hood mat? If this makes a noticeable difference then I just may do this in the spring.100% it does. Here is my sound deadening setup. Engine cover, hood mat backed with 1/4 HDPE foam, wiper cowl insulator from a Bronco Sport which is also now backed with 1/4 HDPE adhesive foam cut to match the shape, fender well insulators. Not in this picture is 1/8 Armaflex pipe wrap on the intake tube where it wraps around the back of the high pressure fuel pump. Injector noise is now at a level I would consider acceptable.
