Driver side bed storage pocket usage?
Archasaurus
Jeff
youtube.com
2024 Iconic Silver Maverick XLT, FWD, Ecoboost
What is the driver side bed storage pocket (which seems to be a bolted on plastic plate) used for? The passenger side has a small cubby hole. I have an XLT, spray in liner, no bed power outlet.
JfredTrem
Justin
Maryland
23 Maverick XLT Tremor
you can add in another cubby ifn you wants to.
Maverick_Innovation_Designs
Gold Sponsor
California, CA
'09 F-150, '22 Maverick
Archasaurus
Archasaurus
Jeff
youtube.com
It would be nice if there was a shutoff switch in the cab, so someone wouldn't drain my battery.
MetalsGeek
Rough
Torrance, CA 90503
Down to just the Mav
I put a second cubby in the driver side of my XLT and installed a 12V fused lighter socket in the forward wall for the air compressor I carry around. Ford calls it a "Loading Compartment Partition. Storage Box" with P/N NZ6Z-60286A72-A. About $45 + tax, or 10K points. If you choose to add a socket as I did, you have to play a few games for the install, since the cubby completely fills the hole in the bed wall as you slide it into position. You will also need to buy a couple more M6-1.0 x 20 mm hex bolts & washers, in black if you want it to match the other side.
AutobahnSHO
Will
S.Carolina
Maverick, Miata
My Lariat had two cubbies, no power outlet (yes wiring). I use cubbies for tie straps, an old tarp, whatever.
Call sign "Slick"
Wain
Houston, tx
2023 Ford Maverick
The power to the bed shuts off automatically shuts down after 15 minutes, preventing any drainage from the bed area. I inadvertently left my bedlights on once. It saved my bacon.
Maverickman74
Shane
Maui HI
90 minutes on mine. I run my fridge off it.
Call sign "Slick"
Wain
Houston, tx
2023 Ford Maverick
Maverickman74, is your Mav a Hybrid? Is this after you turn it to the full "off" position?
