Drain tubes for tonneau cover.
Potatman
Bruce
Kentucky
Escape
I recently purchased a rough country trifold hard tonneau cover and I have the drop in bedliner but I don't see anywhere to run the drain tubes. I used the garden hose and shot water into the bed and I see it coming out underneath. Does anyone know where exactly to put the drain tubes I don't really want to drill another hole in my bed.
They are on both sides.
See the picture.
Unfortunately you're drop-in bedliner probably covers them up.
Good luck
GB
Yes there is dirt in my truck bed. 🫣
Ford Maverick Drain tubes for tonneau cover. 20240818_090203
Potatman
Bruce
Kentucky
Escape
Well that's not too smart a Ford if we're going to put that drop in liner not to have a hole there where you could put your tubes
stevj
Stev
Pacific Northwest
2024 Hybrid Maverick
I chose a different route when waterproofing my cover.
Ford Maverick Drain tubes for tonneau cover. Drain
There was already holes in the forward corners of the bed, so ran the hoses through them, so they would drain out the lowest point rather than running down the bed sides.
Ford Maverick Drain tubes for tonneau cover. Hose
Skisail
Ohio
Audi A4 Avant
It’s easy to remove the sides of the drop in liner. The place to drill the liner is marked on the back and there are rubber plugs to remove in the bed.
ripperAZ
AZ
2022 Mustang MachE 2021 Genesis G90 2032 Mav
My FX four hard trifold steers all the water towards the back of the cab as it folds up and drains it through rubber tubes you glue into holes in the bed you might check the FX for owners manual installation online to find where those holes are because mine drains from tip to end. It’s the main reason I went with the pricey trifold FX four
btas
Northern New York State
Ford Maverick, Ford Mustang, Ford Escape
This is what I did and it works great!
K1ngJ0hn
Kansas City
2024 Ford Maverick XLT
You have to take the bedliner out and on the back side there is a spot that is marked to drill it out. They lined back up perfectly with the rubber grommet when I did mine. Sorry about the glare on the second picture but I think you get the idea.
