- First Name
- Rough
- Jan 9, 2022
- Torrance, CA 90503
- Down to just the Mav
- Engine
- 2.5L Hybrid
Don't forget that the most expensive brake repairs come from internal system corrosion (ABS pump/valve unit is not serviceable). Ford's low-viscosity DOT4 fluid absorbs moisture from the air and distributes it throughout the system. You should ideally flush your brake fluid every 2 to 3 years to prevent corrosion. Inexpensive testers are available to measure the moisture in your brake fluid. They're not perfect, but "good enough" to tell you when you NEED to do a flush. When the fluid starts to change color, you are already too late.
