Does USB plug come with 110V 400W inverter option inside cab?
CatsupGladiator
Milwaukee
Grand Caravan
Just look around you'll find C to C cables at big box stores or Amazon.
huunvubu
coppell tx
2023 Ford Maverick Hybrid
As far as I know the it's part of the lux package.
No it is not part of the lux package.
I have a Maverick XLT (no lux package) and the 110V/400W outlet in the cabin. It has the USB ports next to the outlet..
Ford Maverick Does USB plug come with 110V 400W inverter option inside cab? Outlet
huunvubu
coppell tx
I ordered XLT without lux package, added inverter option. So what you are saying is it doesnt come with that on XLT if I spec out the inverter?
I suppose I can drill a hole and add an Ebay double 2.1V USB port setup where the lux pak has it.
On an XLT with the inverter option you will also have the USB ports next to the outlet.
Andrew9793
Andrew
Sanger Texas
2022 Ford maverick, 2019 Ford Escape
What is the upper USBC port for then. I have never found a Male to Male USBC cable for charging. Maybe I'm just old.
the upper plug is a USB C plug. its the new style usb.. its what the new apples phones use to plug into there charger box.
Braderick
Brad
High Point, NC
Bolt EV, RAV4 Prime, KИ EV6
Built 1/9/23
Now comes with two usb c ports for rear passengers.
Ford Maverick Does USB plug come with 110V 400W inverter option inside cab? C5FAC248-0888-40F5-9DEB-DC547199DA2A
My XL also has the 400w inverter option and is identical.
Note: the rear usb will NOT connect to the dash screen. It seems to be just for charging.
Charge port as indicated by the battery symbol on it.
JBryant
Jesse
Bowie, TX
It is for some newer devices that have C charging. It is direct C to C and not USB to C. My wife uses it all the time.
