Chapystick
Drew
Iowa
2025 Maverick Lariat (Ordered) + Mazdaspeed6
The clunking was only the first generation of springs. They fixed it by the time I got mine. I dont have the adjustable camber bolts on mine. It has a slight angle but its not noticeable.
That’s great to hear, I was on the fence between a level drop with Eibach or the Goodwin springs with a small rake for loads in the bed.
I’m sure the natural camber it gained is probably better for handling anyway, no need to set it to stock, only excess toe is bad
Dmat
Dmat
Baton Rouge
MAVERICK
if you have the AWD, you need the bolts.
Chapystick
Drew
Iowa
Is there a rubbing issue on the inside if you don’t? What’s the reason?
I’m new so I’m trying to learn about the platform and do things right
Dmat
Dmat
Baton Rouge
MAVERICK
I think its because the awd has a different rear end suspension than the fwd so the bolts help keep it within spec.
Chapystick
Drew
Iowa
Oh I hear ya
I would think it’d be that it needs adjustable toe links. I know the FWD rear end is a torsion beam but AWD is a more normal multi-link
Chapystick
Drew
Iowa
Also another important question for you in general, did you cut the bump-stops for that low of a drop?
Dmat
Dmat
Baton Rouge
MAVERICK
I did not do the install so I couldnt say. I assume they followed the instructions which are available on eibach's website.
Chapystick
Drew
Iowa
Sounds good, I’ll have to dig around and check that out
Bad Samaritan
Minnesota, USA
Tesla Model 3, Stinger GT2, 2025 Maverick Lariat
-Diode Dynamic Fog Light Kit (Diode Dynamics)
First of all, very cool build.
I am very interested in the foglight kit. Do you mind answering a few questions?
1. Did you install yourself or had it installed by some professional mechanic? Was that difficult?
2. How exactly did you fit the lights - did you have to cut into plastic, or are those plastic inserts removable?
3. How do you control it from inside the vehicle - do you use an existing switch, or did you put a new one somewhere (where exactly)?
4. Is it always on when the headlights are on? Or are they operated independently?
5. Is there any kind of auto on/off ?
Thanks in advance.
Dmat
Dmat
Baton Rouge
MAVERICK
Thanks in advance.
1. Installed it myself. Having the right tools would have made it easier though. Get a cordless ratchet.
2. There are instruction videos on youtube that diode dynamics created to show you how the full installation works in detail. I would suggest you go watch it.
3/4/5. The installation will have you wire it to come on when you send power to the headlights. There is an on/off switch included if you want to turn them off completely though. It's not required to use.
There is also an F150 switch mod where you install the switch from an f150 powerboost to control the lights. There is a full thread on it that you can find on the forums.
Bad Samaritan
Minnesota, USA
Thank you!
Do you mind posting a picture what the switch looks like in your truck? Thanks!
Dmat
Dmat
Baton Rouge
MAVERICK
Just a little halloween light display.
Dmat
Dmat
Baton Rouge
MAVERICK
So my lighting adventure continues. Just figured I'd show an update. Under glow isnt finished just yet.
