DIY Bed rails question
brielee3
Rudy
VA
Mustang
I got the supplies for the DIY Unistrut bed rail, but am concerned about the M8 that attaches the rail to the truck. 1 inch (25 mm) seems to long, has anyone completed this project and if so what length M8 bolt did you use?
Thanks..
Maverickman74
Shane
Maui HI
Well if you make a insulating gasket between the rail and the bedside, then factor in the thickness of the rails, a washer and lockwasher, then the 3/8" or so of threads, then it sounds about right to me.
brielee3
brielee3
Rudy
VA
Mustang
Fords instructions didn't mention "insulating gasket". I had planned to just flush mount to the truck but will look into some weather stripping.
Thanks
MetalsGeek
Rough
Torrance, CA 90503
Down to just the Mav
Why don't you just stick a toothpick in each hole and see how far it goes before bottoming out on the outer body panel. Remember that the front 2 holes are M6 and the rest are M8.
brielee3
brielee3
Rudy
VA
Mustang
Excellent idea! Thank you
BlueSpec1
Gene
The bedside threaded M6, M8 look like Ford's version of RivNuts.
Probably the backside of them visible in the holes of RedNeck Garage's pict.
Ford's kit has 3 spacer washers they put behind each rail.
Ford Maverick DIY Bed rails question Bed Rail - RivNuts -RedNeckGarag
Ford Maverick DIY Bed rails question Bedside Rail, Cubby - Ford RivNuts
Maverickman74
Shane
Maui HI
Thanks
Thats the thing about modifying what the factory gives us, its always an opportunity to make it better.
