Disable horn beep when locking doors?
rlhdweman
Dan
Random Lake Wisconsin
I must be the only one here that doesn't use electronics to lock up.
I also use the button on the door, it's just easier that way.
Deleted member 35678
Guest
It's in the BCM settings. I believe you can also configure Global Windows to only require a single 2-sec long press, but I haven't tried it.
Ok I figured it out. The guy that said it was in the cluster setting was right. Un check the feedback button under locks. 🔒
DWV
Don
charlotte nc
2024 Maverick
One touch and the doors lock but the exterior lights stay on; two touch with beep and lights go off immediately. I don't particularly care for the loud beep, but want the lights off when I exit- no need to drain the potentially problematic 12v battery un-necessarily! At least that is the way my 2024 XL works.
I park in a lighted garage, folks that park outside may want the lights to stay on while they walk to their destination, if so one push is ideal for them.
Kenny
Kenny
2022 Maverick XLT 2.0 Ecoboost with AWD, Tow Pkg
Have you tried the owners manual or Google? And again, it is beyond simple for the horn not to beep. Mine never beeps, never. And I have not changed a thing.
Didn't be a F-tard, this forum is for people to ask questions. If you're going to send everyone somewhere else then YOU need to leave.
