Dashcam wiring install on DRIVERS side A pillar/dash.
klutch14u
MO
2025 Maverick XL
Bought the 'factory' Thinkware camera setup with the ODBC wiring. Since I'm not tapping into the fuse box on the passenger side, I'm routing the wiring on the drivers side. The end cap on the dash is labeled 'Air Bag', I've got the routing along the headliner and down the A pillar, not sure how to break through the dash where it and the A pillar meet to eventually get it to the floorboard. Anyone have any tips?
elizabethk314
Elizabeth
St. Louis
Escape
The panel that has built ford tough stamped on it, on the side of the dash where the dash meets the door removes and is a clean shot to the bottom of the a pillar. Be gentle when removing initially as the clips and pins are super tight
klutch14u
MO
2025 Maverick XL
Awesome, thanks. So that panel can be removed without first taking the lower on off stamped 'Air Bag'?
Edit: NM, my eyes are getting old and I now see it's all one contiguous panel, got it removed. Should be fairly easy from here. Thank you!
