Rear Dash camera wiring
Chief2008
Gouldsboro Pa
Bronco Sport to Maverick Lariat
How are running your rear camera cable. doesn't look like you can get down edge of headliner along side of truck. Any suggestions on your install or experience
wakkawakka22
Tulsa, OK
2026 Ford Maverick Lariat Hybrid AWD
I went under the top of the A pillar cover to under the secondary door seal to the top of be B pillar cover the the rear door seal to the C pillar cover. I looped the excess and zipties it to the rear bulkhead, and ran the lead to the camera, securing it between the rear bulkhead and C pillar.
daveaquirk
Veneta, OR
2023 Maverick Lariat
You'll need to pull back the gasket near the roof which will give you access to the headliner, et al. Helps to have a "press tool" to help feed the wiring into place. Ran my wires from the rear view mirror down the driver side and affixed remaining excess wire to the rear bulkhead. Good luck!
sanpablo
Rich
Long Island, NY
I simply ran mine between the headliner and rubber trim on the passenger side. I'm not sure if that is a problem with the side air bag?
Vioffo a229 plus
